Question about Sony DHR-1000 DVHS VCR
DV input to DV deck
Dear Fix Ya fixer: I have just purchased via E-bay a used Sony DHR-1000 recorder- to replace my Panasonic DV-2000. The Sony checked out OK until I began a DV dub From my editor (Applied Magic's Screenplay apppliance) to the Sony. The Sony just didn't seem to like the Screenplay signal. It would lock on for awhile, then drop the recording. Then it might come back for a bit, and drop off again. I switched the Screenplay (SP) firewire output to my old Pana 2000 and dubbed that way; got the show out; then investigated some more. Sony's online manual for the 1000 sez: "When you connect the other VCR using the DV jack, the data, index signals and contents of the cassette memory are not transmitted." I assumed that referred to timecode and cassette chip contents, and was standard for all ieee transfers. Or- does it mean that this model Sony might have a problem with some DV input, including input from my Screenplay, a problem not shared by the Panasonic 2000 deck??? Anyhoo, I began a check: On bootup, with firewire connected, the Screenplay signal was steady on the monitor from the recording Sony until the point where the SP graphics menu pops on just prior to its main workscreen menu. At that point the signal (and the resultant recording) began to pop on and off intermittently and for random lengths of time- like it couldn't stay locked on for long. It also drops off when inserting a cassette, on cueing the record tape, and other moves. Jiggling or flip- ending the firewire is no help. The non-signal that is recorded on the tape in the Sony during these intervals is a plain grey screen. However- the Sony deck DOES like the signals (both tape and camera) from my Canon XL1 DV port. When I move the firewire from the SP to the XL1, the signal pops right up on the monitor and holds just fine. The recording on tape is also normal. And feeding signal from the Pana DV2000 to the Sony 1000 also works normally. The tape I fed was a copy made on the Panasonic of the same SP storyboard that would not record well when sent to the Sony directly from the SP. My questions are: Have there been similar problems observed with this Sony model? If so, what is the cause and/or solution? Without such feedback, in order to find if I have purchased a defective machine (or one unusable with my system) I will have to find an identical Sony deck to test with the Screenplay. I still can't figure why recording to the Sony DV should be so troublesome compared to Pana 2000. (Granted, the problem could be with the output of my particlar SP-- but the camera (XL-1) and the Pana deck both accept the Screenplay DV output just fine. Thanks in advance, Mike.
  • 71 Answers
It is a matte of TBC lack your editter don't produce tbc signals with the video out you need to install a tbc board while your old panasonic has built in tbc board regards please don't forget to rate ,thx
Posted on May 04, 2007
SONY DHR-1000NP : Problem : No power Already replaced some components in shielded part of power supply : Replaced big capacitors (1500 and 2200 and 680 mico farad) R115 and FET Q101 will always...
I have just fixed one of these. The problem was C104 inside the metal shielded section of the PSU. It's a 2.2uF 50V capacitor. Sony used an 85degC version rather than a 105degC (which I've used). Fortunately, no other components were damaged.
Feb 17, 2011 | Sony DHR-1000 DVHS VCR
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Oct 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Panasonic DV-1000 Recording Problem
if you are inputting video via the s-video connector, check to make sure the cable is good. you may be losing the color signal in the cable.
Dec 05, 2008 | Panasonic AG-DV1000 Mini DV VCR
Sony DHR-1000
The timer/display control IC501, located on the FM 26 board (right behind the display tube) is likely bad.
the part number is 8-759-368-84.It will NOT be an easy part for an average consumer to replace. You would be better off looking for a complete FM 26 board A7066705A.
Nov 05, 2008 | Sony DHR-1000 DVHS VCR
DHR 1000 problems
sounds like a keyboard problem, but check all the electrolytic caps -- bad caps sometimes produce strange symptoms.
Mar 15, 2008 | Sony DHR-1000 DVHS VCR
Audio Problem with Firewire
The input select switch on the front of the AJ-D230H needs to be in the "OPTION" position, not "LINE". That may help if all the other settings are correct. You will also have to make sure that you have selected the right codecs for the deck that you are using in the software. I am speaking as a Final Cut Pro user so only offer this as a suggestion as these are the things that work from out of Final Cut.
Good luck. It can be very frustrating, but awesome when it all comes together and works right!!!
Helen
Oct 24, 2007 | Panasonic AJ-D230H DV/Mini DV VCR
Panasonic NV GS 400 mainboard problem
What he probably means is that the IC that "Drives" the "Port' has been damaged or destroyed, a very common problem. Due to the manufacturing method, IE: Surface mount compnentry, there simply aint no "Simple Soldering problem" fix, at all... the actual IC, must be replaced... but this isn't actually possible..(well technicaly it is possible, but real hard to do) so hence the only other "Fix", a board replacement. Although ya DV outlet is kaput... If there is another output? say an A/V out? could you not use that as a work arround?
Aug 31, 2007 | Panasonic NV-GS400 Camcorder
Sony DHR-1000 DVHS VCR Logo
473 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
