Question about Panasonic TH-42PWD5UY 42 in. Television
TH-42pw5 Monitor with 5th of screen missing
I aquired this monitor with no history of the thing. Switches on ok but has a fith of the screen missing and this then causes interference to spread out at least half way across the screen. The black part also has coloured bars running vertically, which change depending on the picture viewed. It just flickers by it self sometimes which makes me think it is a connection problem. The right side of the screen is fine with a clear picture. One forum i have read states it might be the screen that needs replacing but I think (hope) it is one of the boards. If any more info on this is required, I will give as much as i can. I have opened the back and found that a ribbon cable has been removed and not been replaced on the lower right C1 board, second from right. I plugged it in with no change to the problem. Please help.
  • Wayne Ferguson Mar 06, 2007
    This is the last comment with added extras:
    Please help.
  • 4 Answers
Can you post a picture of the fault?
Posted on Mar 05, 2007
"Out of Range"
OK, when you boot up next time press F8, and choose BOOT IN VGA MODE, this will then allow you to ar view the monitor, now, go into settings and make sure your video card resolution settings are set to say, 1280x1280, or maybe even less to start, say 1024x768, all 32bit. Now, when you restart next, the monitor should be OK. But, if it doesn't you will have to do it again, set lower, and then get a new Video Driver, and install, and try again, at the higher settings. If you cannot even boot up in VGA Mode, then i suspect the Monitor is faulty.
Apr 14, 2010 | AOpen F2705-8S (Black) LCD Monitor
I have a Panasonic th-42pw5 plasma screen
most likely it is the buffer boards and the z sus
Feb 12, 2018 | Panasonic Televison & Video
My moniter is not working at all, is it posibel that the power suply is the problem?
Yes that is the first thing to check. Make sure the power cord is plugged into a good outlet and plugged into the monitor. If it still does nothing use a volt meter and check to make sure th power cable is good. If the cable is good you may have a bad switch. If that is the case unless you are familar for electronics take the monitor to a repair shop and don't try to take the monitor apart to start checking switches.
Mar 18, 2010 | Apple Cinema 20" LCD Monitor
Monitor suddenly died..replug it and it has power for a couple of seconds but then no power..is the ac adapter the problem and needs replacing? or is the monitor history?
no no the monitor is not history yet :)... it's your adapter maybe. try holding the adapter tightly when you insert it. check the monitor while holding the adaptor.. that should help you find out
Aug 01, 2009 | Fuji FP-988D 19" Flat Panel LCD Monitor
Greeen filter?
?? the colour of the OSD is OK but the rendering of your video signal from the 'pooter is wacky? Either the video cable or video drive from the 'pooter is the cause.
May 01, 2009 | Acer AL1912 19" LCD Monitor
Base missing, need replacement parts
I believe this may be you contact link.The   I-800 ...   number is at the bottom of the page.
http://www.sys.com/help/support/components_peripherals.asp
Feb 27, 2009 | Sys Technology SYS 172L-C-JT 17" Flat...
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Xo vision XO1943BT
CHECK YOUR WIRES AT THE HARNESS WITH A TEST LIGHT TO BE SURE YOUR GETTING POWER TO THE HARNESS.AND A GROUND AS WELL. ANOTHER WAY TO CHECK IS TAKE THE UNIT OUT AND CONNECT DIRECT TO THE BATTERY UNDER THE HOOD
Aug 25, 2008 | XO Vision MD068 6.8 in. Car Monitor
Monitor issue
Open Control-Panel-Display, click on "Settings tab".
Use the slidet to change resolution.
Your monitor should be 1440 X 900.
Click "Apply"
If screen is OK, click "OK" on popup prompt.
if display goes dark, wait 15-20 seconds and it will return to where it was before.
Also: you can click the "Advanced" button
Click on "Monitor" tab.
Adjust "Screen refresh rate to 60 hz or 75 hz.
Jul 10, 2008 | AOC Computers & Internet
Brightness and contrast screen in center of monitor and can't remove it
the micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
Dec 15, 2007 | Dell E173FP 17" LCD Monitor
Panasonic TH-42PWD5UY 42 in. Television Logo
130 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
