Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Le40r7 my picture has some faint wavey lines on dvds and certain cable channels resulting in mainly background interference and flickering,any ideas?
    Problem Solver:
  • 5 Answers
Hi, maybe this will help:
1.  Are you watching US/imported DVDs?  If you are, you need to go to your DVD player's setup / system menu and (if the option is available) set Video Output to MULTI or AUTO instead of PAL.  This will stop nasty, cheap PAL converting going on.
2.  I know it sounds simple, but a lot of people don't check this: check that all of the connections on the back of the TV and equipment are pushed in fully (and, if possible, try different SCART leads).
3.  Is all your equipment plugged into one of those surge protected extension leads? It should be, to minimise interferance.
4.  Keep energy saving lightbulbs, wi-fi products, mobiles, computers and laptops away from the equipment as they can interefere.
Hope that helps!
Posted on Dec 31, 2008
Horizontal lines pop in sound on certain channels
Check all of your ground screws on the boards that you replaced. Sounds like that once the set is getting hot, the board is expanding and shorting out on the screws.
Mar 15, 2013 | Televison & Video
White wavey lines with dots or speckles.
The "white line" at the top of the screen is usually associated with "VBI Information" - the stuff that carries closed captioning, etc. This is usually only visible on upconverted SD material on HD channels and is usually the fault of the affiliate not doing the upconversion properly.
Oct 20, 2008 | Televison & Video
No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
biigg53566
Feb 19, 2009 | Insignia Digital-to-Analog Converter for...
Wavey lines in the picture
Ok I have had this same problem before sadly unless you now how to configure everything you will need to call a close repair man for it they come re-aline the colors But note: this is not free! i'm Sorry But this is the best i can do hope it helps
Nov 26, 2008 | LG 42LC2D 42 in. LCD HDTV
Xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Oct 07, 2008 | Microsoft Xbox 360 Console
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
