Question about iiyama AS4332UTBK (Black) 17 in. Flat Panel LCD Monitor
No signal on the iiyama
I have no signal on screen help help
the pc is working fine only the iiyama as4332utbk has no signal
manny thanks
  • sophb Apr 20, 2009
    it seemed to work fine before when using with my macbook but it now comes up with signal frequency is out of range please change signal timing
    how do i do this?
Have owned a iiyama 17" pro crt for a few years,
These were a fine monitor and with the kind of image quality you cannot get on TFT's.
If you know the graphics card you are using is working ok, have checked the VGA cable connection and socket at the monitor and computer and have tested the monitor on another computer, that would rule out any problems as far as connected devices are concerned.
The problem you describe, and it is unusual that it has happened so quickly, points to a failure of the monitor internal board. You may be able to get this repaired at a reasonable cost by seeking the opinion of a TV repairman, who might be able to fix it.
Jul 25, 2011 | iiyama Vision Master Pro 400 (White) 17"...
No signal. Power is on, cable functions well (tested on other computer). nevertheless, the screen does not work (any more) and shows signa " no signal" . What can have gone wrong with my screen...
The fact that you see the "No Signal" message indicates that the display is functioning properly. The problem is with the input section. Verify that you have the correct input selected. Other than that, the input board is the likely defective section. This is not uncommon and will require service. This is not likely to be a DIY repair if the input board is defective.
May 29, 2011 | iiyama Prolite E430 17" LCD Monitor
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Out Of Range
Do the same procedure you do to enter "safe mode" but this time choose the "start in VGA mode" option, then change windows resolution.
May 08, 2008 | iiyama ProLite E380S-S 15" LCD Monitor
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
Iiyama prolite e483s. no sound
Get a cable two male ends. Look for the female end on your screen. Put one male end into the port on on your screen and the other end into the port "AUDIO ONE" on your computer.
Try this it should work. The Multi-PIN cable is only for VIDEO, you need another cable for AUDIO.
Jan 27, 2008 | iiyama ProLite E481S-B 19" LCD Monitor
Problem with display
Some iiyama's have 2 inputs. One DVI and one analog. Also, some of the older ones used BNC connectors. What I'm getting at is make sure you have the right input selected in the monitor's menu. Hope this helps....JF
Apr 02, 2007 | iiyama S 900MT1 (White) 19" CRT Monitor
Yamaha iiyama 17NE1-S white vertical colum
give it a light bang with your hand to the side.. really.. it says so on their website. it happened because of dis-alignment of some grid, probably happeden during transport
Aug 13, 2006 | Yamaha iiyama 17NE1-S e-yama 17" LCD...
iiyama AS4332UTBK (Black) 17 in. Flat Panel LCD Monitor Logo
61 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
