Question about Samsung Yepp YP-35H 128 MB MP3 Player
Formating Hi My problem is ,when I finish laoding my songs,after I unplug from my pc.My mp3 player says please reformat.I reformat. everything is formated.Then I'll load it again still the same message.Please help.Thanks
  • 6 Answers
Well i heard of a couple of reasons why this may happen, but i cant promise any of these will work but you can give it a shot. 1. there was a couple of issues with older firmware try re flashing with newer version and then formatting it. 2. i heard that in some cases you will have this problem when you have duplicate songs in it, see if you can go trough your music library to see if you encounter an duplicate songs and delete them, its weird i know but i heard that works.
Posted on Jul 29, 2007
SOURCE: YP-55 Not working
i have the same exact problem what should I do?
Posted on Aug 16, 2007
  • 8 Answers
SOURCE: Le mon MP3 Player Capacity 1 GB Plays MP3 , WMA , WMV , ASF and WAV
try this
i found a good step by step tutorial to restore the firmware in
and the software can be downloaded from
(just find "yp-t9 firmware")
Posted on Jan 15, 2008
  • 25 Answers
SOURCE: Samsung MP3 Player YP-Z5F
is there a reset button [pinhole] on the player??
should fix it
Posted on Feb 02, 2008
SOURCE: big problem
I had the same issue.
Format the mp3 player again choosing "restore defaults of the device" (and format using FAT).
It will work again
Posted on Aug 01, 2008
SOURCE: a base mp3 player model gk915
Double-check that the files on your base mp3 player are in mp3 or wma format
Posted on Jan 21, 2009
0 characters
1 Points
I cannot transfer mp3 songs downloaded into my pc to my ipodnanoa1199
After playing 1 or 2 songs, it stop working and at bottom of display I have file error and by formating or by virus scanning and loading new files,everything happen again.Please help me!!!
Jan 06, 2010 | Apple iPod Photo MP3 Player
Mp3 player
This player will only recognize certain song types - you are probably trying to laod songs that are in the wrong format. check your manual for acceptable file types.
Jun 04, 2008 | Delstar DS 31024 MP3 Player
System corrupted
I would advise backing everything to you PC, reformat the player and then putting the songs back to the player.
May 10, 2008 | RCA TH1101 MP3 Player
Not adding songs?
You will need to reformat the GoGear in Windows Media Player, but do a firmware upgrade first - open the Philips Device Manager and click on the Update tab. Then click the update button. After the firmware upgrade is done, open windows Media Player.
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your GoGear to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Philips Go Gear SAXXX" (wording may vary slightly), and then select "Format." - this should erase everything, and make your player properly read in Windows Media Player.
-Tha Mp3 Doctor
Apr 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Sansa e280 not working
I had the same issue. Plug the player in your PC. Go to "my computer" right click the Sansa player. Go to Properties and then select the "tools" tab. Run the error check and the disc defragmentation
Mar 25, 2008 | SanDisk Sansa E280 MP3 Player
Incorrect format
The songs that you loaded onto the player are not in the correct format - iTunes, DRM-encrypt. WMA are not allowed, for instance. Convert everything to mp3 format. It is asking you to reformat the player because it wants you to delete the wrong-formatted songs off the player. I would check your user manual to find the best way to reformat.
In general, though, there are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Mar 03, 2008 | AIGO F008 MP3 Player
My Sandisk Sansa m240 lost all the songs and then I could not delete them. I was able to laod up new songs, but there was no spare memory. I was able to fix this issue by re-formating.
Using windows explorer right click on the "Sandisk sansa M240" and click "format".
Now working OK.
Feb 20, 2008 | SanDisk Sansa m240 MP3 Player
Craig mp3 122 mg
When you put songs on your mp3 player don't put them in folders if you do.
Also did your mp3 player come with any software, you may need to use the software in order to put songs on.
When you've finished putting songs on do your safely remove your mp3 player from the computer, if not that could be your problem.
Also it could be anything from a small read error, try formating your mp3 player which may fix this problem to do so follow these steps below:
First connect your mp3 player to the computer, once you've done that go to "Start" - "My Computer" - now look for something called "Removable Disk" which is your mp3 player, once you've found it "Right-click" on it then click "Format", once format as complete put music back on your mp3 player, then see if the problems been fixed.
Good luck. Hope my solution was helpful in some way. Further problems, leave a comment on here and i will get back to you a.s.a.p.
Nov 22, 2007 | iLO (2 GB) MP3 Player
hi try formating the mp3 then check if it still has the music.
Jun 30, 2007 | SanDisk Sansa e250 MP3 Player
Formating problems
The H140 needs to be formatted as a fat32 file system for the players firmware to recognise it. To check which file system you have formatted to connect your player to your pc and go to > my computer >right click on your player > then click on properties. It will tell you what file system you have. Windows will only format to ntfs file systems, so if you need to reformat you will need to download Swissknife (its free :-) )and use it to reformat your player.
Jan 13, 2007 | iRiver iHP-140 MP3 Player
Samsung Yepp YP-35H 128 MB MP3 Player Logo
44 people viewed this question
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
