Question about American Standard Bath Faucet Ceramix 2000.500 002 Chrome Bath/Shower Fauce...
Slow and nonexistent water flow.
I have an American Standard 6310 series combi faucet in my kitchen. I noticed the water flow was slow, so I removed the hot water supply and cleaned out the mineral deposits. Put it back together and then had no water. There is water above the manifold, but when you put the cartridge on, no water. Called American Standard--they said I needed a new cartridge. 15 days later new one appears and I installed. First a slow drip of water and then nothing again. What now?
  • 1 more comment
  • blbwilliams Dec 11, 2008
    Thanks for the suggestion. I tried it and I get just the tiniest stream of water.
  • sbauer128 Dec 26, 2008
    Same problem, but I already checked and cleaned the spray head. Stilll no water???
  • Anonymous Mar 30, 2014
    Water is coming out in a slow stream
    Scholar:
  • 68 Answers
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Posted on Dec 11, 2008
Thumping in the kitchen water lines
You have a water valve or back-flow preventer slamming closed, somewhere...
Mar 03, 2014 | American Standard Kitchen Faucet 6310 020...
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
I just installed an American Standard easy touch faucet 6310F. The pressure is very low. Anybody know what the problem may be?
At the base of the handle there is a flow regulating check valve. Shut off water supply and unscrew handle and look for debris. Many times the washers break down on the shutoffs under the sink and release "crumbs", these usually block aerators and sometimes the cartridges on certain faucets. Hope this was helpful.
Feb 16, 2011 | American Standard Kitchen Faucet 6310 020...
IF HAVE A AMERICAN STANDARD KITCHEN (6310) . I JUST READ THE PART TAKE FACTCET APART AND TURN ON WATER . I DID THIS AND GET WATER ON COLD SIADE BUT NOT ON HOT. THIS IS WITH CARTRIDGE OUT .DOES THIS TELL...
It says you have a problem with the hot water. First thing to do is to turn the hot water supply valve under the sink off, and then remove the line from the valve to the faucet at the valve. Then put a bucket underneath the valve and turn it on (carefully). If you don't get any flow, then the problem is in the valve or the pipes supplying the faucet. If you get flow there, then the problem is in the supply line or possibly at the faucet.
Jan 18, 2011 | American Standard Kitchen Faucet 6310 020...
We have a problem with the cold water flow as it just trickle out. The hot water flow is fine. We have the Combi Faucet 6310 series
I would check take apart the cold flex connector and check the flow when running water into a bucket, if it is wimpy then there is a blockage in the angle stop or the flex connector. If it is good you will need to take the cartridge out, check for signs of debris and possibly replace it
Jun 27, 2010 | American Standard Kitchen Faucet 6310 020...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
Slow flow, spray will not stay on.
you need pressure to make the spray stay on so maybe check the valve under the sink to see if it has turn almost off, that happen when the pull out nozzle gets returned and the heavy weight on the hose hits the hose
Jul 20, 2009 | American Standard Kitchen Faucet 6310 020...
American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
Apparent flow blockage
I would turn off the water then check to make sure you have good flow up to the faucet itself. If you do then there might be a proplem with the cartridge or diverter. does it have a sprayer? If it has a sprayer head for the spout of the faucet then there will be what the call a check valve inside the spray head itself that canbe removed with a skinny screwdriver or something thin and long
Apr 29, 2009 | American Standard Kitchen Faucet 6310 020...
American Standard Bath Faucet Ceramix 2000.500 002 Chrome Bath/Shower Fauce... Logo
741 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
