My router is tempramental and comes up with limited or no connectivity. It also says windows cant detect an ip address and i need to get hold of the manufacturer?
  • 837 Answers
Have you tried turning off your internet connection (i.e. cable modem, dsl modem, fios modem) and your router and pc's. Then after about 5 minutes turn on the cable/dsl/fios modem, wait 1 minute, turn on router, wait 1 minute, turn on a pc. Try surfing
Posted on Dec 11, 2008
I cant access to the wi fi..it says limited access and no IP address connected. How can I resolve the problems. I'm using SOny Vaio S Series with i3 processor Thanks, Raymond
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
May 20, 2011 | Computers & Internet
I cant connect my dell laptop nor detect D-Link dlink Wireless N 150 Router through wifi but my mobile devices can and my desktops can also. please help me able to connect in the internet using wireless...
Try assigning your laptop a static IP. To do this in Windows:
  • Open Windows Start menu.
  • Open Control Panel.
  • Classic view: Open Network Connections
    Category view: Select Network and Internet Connections, and thenNetwork Connections.
  • Double-click on your active LAN or Internet connection.
  • Click Properties
  • In the General tab, highlight the Internet Protocol (TCP/IP) item, and clickProperties.
  • In the General tab, click Use the following IP address, and enter: - IP address. The static IP address you want to assign to this computer (try 192.168.1.110 to start). - Subnet mask. Subnet mask used by your router (try 255.255.255.0 to start). - Default gateway. IP address of your router's default gateway (try 192.168.1.1 to start).
  • In Use the following DNS server addresses, enter all the IP addressses for the DNS servers your router uses (or you can try your router's address, probably 192.168.1.1).
  • Click OK.
Source: http://www.hotcomm.com/faq/faq_staticipxp.asp
Please leave feedback for this answer, thanks.
Mar 10, 2011 | D-Link dlinkgo Wireless N 150 Router...
On my windows vista dell laptop it say limited acess to linksys
"Limited access or no connectivity" message comes when there is issue in ip configuration for that enable DHCP in router then set ip get automatic in your windows network adapter's tcp ip property. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then enable DHCP save settings and restart router then go to your windows network adapter tcp ip property then set ip get automatic.Then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
Aug 06, 2010 | Linksys WCG200 Wireless Cable Modem 54G...
Wireless computer limited or no connectivity, ip address assigned is 169.254.96.158
You did not specify an Operating System but I'm going to assume you are using Windows XP.
Click Start > Settings > Network Connections - Right click your Local Area Connection and select "properties".Select TCP/IP and click the properties button. Make sure that both "Obtain an IP address automatically" and "Obtain DNS server address automatically" radio buttons are selected. Close both windows by clicking OK, then power cycle the router by unplugging it for 30 seconds. Windows should automatically assign a new IP address to your router.
Nov 07, 2009 | Linksys Wireless-G WRT54G Router
Get message, Windows has detected an IP address conflict, another computer has same IP address as this one. get this when trying to connect to web after it has connected to dlink that is on the list of...
It appears that at least two of your computers get the identical IP address assigned from your router.
First step: Make sure your router is set as a DHCP server. Log into your router's web interface and check if that's the case. (If you need help with that, tell me make and model of your router)
Second step: Go to the computer that has the IP address conflict.
  1. Click on the start button
  2. Go to Control Panel -> "Network Connections"
  3. You should see an icon labeled as "Local Area Connection" (indicates a wired Ethernet connection) and/or "Wireless Network Connection". Check both - one after the other.
  4. Right-click on the first icon, choose "Properties".
  5. In the next window, in the middle you will find a list of items, one of which is "Internet Protocol (TCP/IP)". Double-click on it.
  6. In the next window, select "Obtain IP address automatically"
  7. Also select "Obtain DNS server address automatically"
  8. Click OK to close this window.
  9. Click OK a second time to close the second window.
  10. If you have more than one connection type, go back to step 4, right click the other icon and choose "Properties". Repeat steps 5 to 9 for this other connection.
If you have any more questions or need assistance in any of these steps, just come back here and leave a comment - I'm happy to help.
Aug 14, 2009 | Belkin Computers & Internet
NIC Connection question, Manual in XP, Automatic in Linux
Its depend on your LAN Card Configuration, something it obtain or directly detect your internet connection but sometimes its not. That is why to make sure that you can connect you manually put IP Address on it. Uncheck the limited or no connectivity on the Lan Setting to make that when you are using Obtain IP Address then it shows and detect your Router or Hub with internet provider.
Jul 29, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
One computer connected the other limited or no connectivity
When using a router your IP is assigned to your Router. Then Your router assigns IP's to whatever is hooked up to it. Set everthing to detect automaticly. Might delet connection and create a new one.
Mar 11, 2009 | SMC Netgear 5Port Gigabit Ethernet Switch...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Cant IP Address
press F11 when turning on your PC
Jan 30, 2009 | Microsoft Windows XP Home Edition
Cant accses router
Pressing and holding the reset button on the router for about 5 seconds should reset the router, but you may need to connect with the router via an RJ45 network cable incase the wireless is not able to set it up The default ip address of the router should then be 192.168.2.1. do not use the windows repair wizard as this totally messes up your pcs ip address, make sure that your network wireless and wired adapters, are set to obtain an ip address automatically You shouldnt change the PPOE or PPOA settings, as they are the settings on which your ISP allows your router to connect to the server. Manually entering an ip address will effect the address of the router so keep the settings as enable DHCP to assign ip addresses automatically. Ensure when you have it running you save the settings so as you can reinstall them if neccasary.
Aug 20, 2007 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
