Question about D-Link DP 301U (DP-301U) Print Server
D-Link DP 301U Print Server not continuous print from vista
I have a vaio laptop with vista platform.
I have also a HP laserjet M1120 MFP all in one printer.
My print server model no. DP-301U (ver : A1).
When I install the print server then test page printed 'OK'.
But any document I want to print then print only one page and an
information displayed bottom of desktop "print documet failed".
After this, not any one page will print.
  • Anonymous May 12, 2009
    Same issue here. I have a desktop with XP that hooked up immediately and printed fine.
    My laptop has Vista, settings are exactly the same as the desktop, but when I print, I get a half of a page to print then it stops and says "Error"
    Then can't print from the laptop anymore until queue is cleared out. However, even if the documents in the Vista queue are in error, I can still print from the XP desktop.
    Problem Solver:
  • 5 Answers
Make sure you have byte counting enabled if you are printing through LPR.
Posted on Jul 31, 2009
I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Oct 20, 2009 | D-Link DP 301U (DP-301U) Print Server
Printing Problem
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
Using HP Laserjet P1006. Is it compatible with DP-301U
Yes. I just got mine working last night. Key is to enable print services for windows through the control panel. Without that LPR printing does not work.
Jun 08, 2009 | D-Link DP 301U (DP-301U) Print Server
Print server DL-301U setting
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1006 is NOT in the list):
Apr 14, 2009 | D-Link DP 301U (DP-301U) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
Communication between PrintServer DP-301U and HP LaserJet 1020
Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
Alex
www.CAS411.com
Feb 13, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    DP301U COMPATIBILITY
    I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
    LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
    Feb 09, 2009 | D-Link DP 301U (DP-301U) Print Server
    Documents not printing
    Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
    May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    1,342 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
