Promble with files folders and softwares
I have problem with my instlled softwares eg. when iam opening the software folders they are opening with windows media player and when i went to the properties of that folder i came to know that the target type is media player. please resolve my problem laptops model no is satellite L310
  • 46 Answers
Hi
You try to restore the system to a previous date when th problem had not occurred.
Assuming you a windows user -- press windows button -all programs-accessories-system tools-system restore.
or Press windows+r --write rstrui.exe.
hope it works.
waiting for your response.
Posted on Dec 11, 2008
Hi! I own a Seagate Free Agent Go 320GB(Flash Memory). I can't see any files or folders in my drive(Here i.e I:). But when I checked the properties of the drive it showed me 99GB free out of 298GB. I tried...
There is a login that needs to be done on this drive with the software included with the drive before you can see the files, they are hidden until you unlock the drive
Jan 01, 2011 | Microsoft Windows XP Professional
When I Donloaded Sniper Ghost Worrier It was in .iso format i opened it with Israck the PROPHET folder is not extracted WHY?
You don't extract the contents in any iso files in the way you are doing, you just burn image iso files to an CD/DVD using any image burning software eg imgburn, nero, magicISO, etc....and install the software from the burned CD/DVD.
or
You can load the iso image with a virtual Drive,(ie if you virtual Drive support iso format), and install the software from the virtual Drive.
Hope it helps.
Dec 12, 2010 | Computers & Internet
I installed recently HP officejet Pro L7480, but hP solution center failed to detect any device and closed. the officejet also failed to scan - error message: No scan option
Hi There, This is a known issue with this device. Please follow the below steps to fix this issue : Try to do a complete uninstall
*first step*
-run installation media (CD / Download) software
-select uninstall and on the process, select uninstall all hp softwares associated the with the device
-after uninstall , select restart later to reboot the computer later
-go to start > control panel > add/remove programs (XP) programs (Vista)
-uninstall any existing HP softwares (note: for hp computers, skip this process)
-restart later
*2nd step*
-open contents of the installation media
-if you're using the installation CD. go to my computer, select the drive which has your cd in (eg. E:/ , D:/ ) right click on the icon and select open / explore.
-if you're using a downloaded software, click on start and click on run (XP) startsearch (vista), on that box, type in the command ( %temp% ) and press enter. it will open up temporary files folder.
-locate the file that starts with 7z (eg. 7z001cs1) and open it and now you are in the contents of the installer
-on the contents of the installer, locate UTIL folder and open it then locate CCC and open it as well
(note: check your operating system if it is running on a 32-bit or 64-bit . you can check it going to start>control panel>system)
-on CCC folder , locate uninstall L1 (for 32-bit) uninstall L1 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
-on CCC folder , locate uninstall L2 (for 32-bit) uninstall L2 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
on CCC folder , locate uninstall L3 (for 32-bit) uninstall L3 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later (repeat uninstall L3 steps for 3 times)
**********important**********
(do not run uninstall L4)
contiunued in the next post ..............................
Nov 14, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Cannot install microsoft office professioanal 2007 onto my computer. says a setup exe is missing. what can i do to fix this problem
1.Check if the location pointing to the source of installation files is correct. As for eg if the drive letter is changed , change it to point to the correct installation files . ( for eg if you are installing from CD and if CD is mounted in F:\ , then change the drive letter to F:\ )
Or if that doesnt work please try this
2. In windows explorer, under Folder and Search Options - View - 'Hidden files and folders' should be set to 'Show hidden files and folders?' and "Hide protected operating system files?" should be unchecked.
Mar 09, 2010 | Computers & Internet
I'm trying to use the scanner to scan some documents and store it in a folder in the computer. Can you help me with this? Ray
Your software will usually ask where you want to store the document once it's scanned. A lot of software is intuative enough to guide you through each step.
Aug 19, 2009 | Office Equipment & Supplies
Unable to open Pendrive
Your pen drive is infected by a virus/worm. I have two solutions for this -   > If you have WinRAR software, just open up the pen drive using this and delete "autorun.inf" from it.  OR  > Use any good antivirus software and scan your pen drive, and disinfect the pen drive from any virus/worms. Remove your pen drive, and insert it again. It'll work fine.
Dec 25, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
No new icon even after the program shows successful completion
OK, if the program can be found in the start menu, (Start/all programs/ "the program")
Then right click on it and select " Send to> " move across the next select box which appears and select " Desktop (create shortcut)
If your program isn't in the start menu, then go Start / Control Panel / Add or remove programs (XP) OR Programs & Features (Blista) check if the program you installed is listed, if it isn't reinstall it, if it is, Right Click on Start and select "Explore" Find the Folder in the tree called Program Files, in that folder find the Folder with your program name, in that folder drill down to you find the program name .exe (it will be type Application) double click and find the one that opens the required program eg. CinePlayer is here, Local Disk (C)/Program Files/ Roxio/Digital Media Plus/CinePlayer/CinePlayer.exe
Right Click and select Desktop (create shortcut) and/or Pin to Start menu
Sep 28, 2008 | Computers & Internet
Installation of cracked version of catia v5r16 software
the version have been corrupted while cracking.so
use fresh products
Apr 13, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
