Question about Intel Biostar IDEQ200S P4 Barebone System (BBIDEQ200S)
My system is restarting
Hi all
Hi friends my system having a problem that is it’s automatically restarted in running a program or inter net open,
My system confirmation is,
Motherboard BIOSTAR®
RAM 1GB
HRD 160GB
I can install a new O/S XP2,I can change my mother Board (Biostar) I can change my RAM 1GB so what can I do? Please tell me
U just open the system in safe mode one time and scan syatem through an antiviruse.........if it helps then it ok and if not then u have to format ur pc
Posted on Dec 11, 2008
When i shut down my computer, it automatically restart. i tried to correct it by removing the power and restart button before shutting down, still it would restart.
If u have installed any new program then uninstall it , or restore ur pc,
It may be a fatal error that is causing the computer to restart. You can easily stop the restart problem by changing your system features to restrict automatic startup when your computer's having a problem. Here is how:
There could be spyware problem or some kind of antivirus. Scan it with good antivirus.
Use System Failure Settings to Stop Automatic Restarts.
1. Click Start and Open the Control Panel
2. Go to System and Maintenance, Click on System.
3. Select Advanced System Settings and choose Advance tab.
4. Under Startup and Recovery, click on Settings.
5. Under System failure uncheck Automatically restart.
Another cause for random reboots is that the computers processor is getting too hot. To check this, enter the computers bios during boot (usually by pressing Delete, F1 or F10 when the computer just starts) and there will be an option about the computers temperature (often under
Sep 12, 2010 | Microsoft Windows XP Professional for PC
Inter net does not work on laptop
You will have to uninstall ( Reset ) Internet Explorer and Reinstall.
To do so :
XP User
1. Open Control panel in Classic View
2. Open Add/Remove programs
3. Click on Windows components on left tab
4. from the list - Uncheck Internet Explorer
5. Click ok and restart the PC
6. Open Control panel and Add/remove programs
7. click on winows components
8. Put a Check on Internet Explorer and click ok and restart the PC
You can then download the latest Internet Explorer from Microsoft Website
Vista User
2. Open Programs and Features
3. From the list chick on Internet Explorer Self Tool
4. Click Change button on top tab
5. Continue with the instructions on screen
OR you can choose Repair option on Tab to Repair any broken coding in Internet Explorer
Jun 16, 2010 | Mozilla Firefox
Microsoft .NET Framework (KB951847) not installing
  • Hi, there are a few things you can do to see if the "Software is installed. The first is to go to the Control Panel's (Programs), Uninstall a programs, you want to view that the software is present. If the software is listed? Try to (repair, or change the program). Next, open the Task Manager from the Desktop, (right) click on the Taskbar to open. In the Task manager you want to open the Services... click on the button. In the next window, scroll through the listings to find the Microsoft. Net... click to open, and see if its (Enabled; if the service is running), if not? Enable the service, Start the service, select "Apply and OK." Note: Most changes, updates, downloads.. require the computer to be restarted for the applications to take effect. "If the solution helped?, "Ratings is appreciated, thanks"
Feb 19, 2010 | Microsoft Network Programming for .Net...
Volume control icon missing from my desktop
Hi friends,
This problem is due to some virus attack on to your computer...Scan through antivirus
or
Generic Host Process for Win32 Services Error is a broad issue.microsoft has a patch for this issue.You may download the patch KB894391, to fix this issue.
or
Alternatively you can do windows update manually (Note that the above patch solution and the following windows update solution works only on PC/computer running genuine Windows and not pirated versions):
  • Go to the start menu
  • Right click “My computer”
  • Click “properties” then the “automatic updates” tab
  • Choose “turn off automatic updates”
  • Restart your computer
  • Go back to start menu and in all programs go to “windows update” you have to be connected to the internet
  • Manually update windows
  • Turn your automatic updates back on
You can also try the following solutions to fix this error:
Solution 2:
  • Go to Run and type regedit
  • Navigate to HKEY_LOCAL_MACHINE >> SYSTEM >> CurrentControlSet >> Services >> Browser >> Parameter
  • look for the key IsDomainMaster
  • Set its value to False
  • Restart the computer
May 13, 2009 | Computers & Internet
Automatic restart
This is may occur due to following reasons:
1.please check BIOS power settings..
2.If boot file got corrupted this issue may occur.
trouble shooting steps:
Open Command prompt in Computer
Start >> Run >> type cmd >> press enter.
Now type chkdsk /f
now type : y
then restart the PC it fixes the boot file errors.
Clarifications required:
Please let me know are you getting any error while restarting computer. While Startup Windows XP does it opening any programs automatically or not?
Feb 18, 2009 | Acer TravelMate 2300 Notebook
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Motherboard repair
clock section 3055 trasister change
Aug 27, 2008 | Intel 845GE Motherboard
After i load ssp2 my computer does not open window program
What is 2.2 frame?
Do you mean .Net framwork 2.2 update from microsoft?
Press & hold the power on button on the E-Machine. That will shut down the PC. Unplug the power cord from the power supply. Wait a minute. Re-connect the power cord to you're PC & press the power button on you're PC. Windows should start & may run check disk before loading windows. Continue updating windows through windows update service. There are more
.Net framwork updates. If you're system continues to run restarting shut it down as before. This time when you start up the PC start pressing the F5 key every two seconds. Windows Advanced Option Menu will load. Choose Safe mode. Open control panel, open add/remove programs. At the top of the window & slightly to the right of the Add or Remove Programs windows is a box next to Show Updates. Left click in the box. Scroll down & find .Net framwork 2.2 & uninstall it. Close all opened windows & restart the PC.
Continue to update you're windows.
Please let me know if this has helped.
Good Luck!
Mike
May 08, 2008 | E-Machines eMachines Desktop PC
Not getting ping
hi
check your ip addresses.
remove program of any inter net client in add remive program.
restart both sys at same time.
Mar 26, 2008 | Microsoft Windows XP Professional
Intel Biostar IDEQ200S P4 Barebone System (BBIDEQ200S) Logo
89 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
