Question about Sylvania 6615LE LCD HDTV
Having a problem with my samsung camera monitor because of fuse
The fuse allways blows when i replace a new one what could be the problem? what is the other component of my t.v should i check pls help me.
WANT TO UPGRADE FIRMWARE. SCREEN GOES BLANK
Allways read about the serial number before flashing firmware or the wrong firmware revision was loaded for this model ?
firmware chip replace by new or lend a chip with an appropriate revision start and create a hot-swap by reinserting the old chip and re-flash the correct firmware in it, because he will likely continue to boot black
Feb 25, 2016 | Samsung 2232GW
Samsung nc10 charger blowing fuse?
The charge adapter is faulty. You need a new power adapter for your model Samsung notebook.
May 20, 2013 | Samsung NC10-14GW Notebook
I have a Samsung Rear Projection TV with an HDTV 1080i Monitor. I know the convergence is messed up because the blue would not move when I tried to adjust it on the menu. So, then I tried to make it
You will need to replace both convergence Ics and the pico fuses that blow when the Ics fail. You can get the replacement Ics and pico fuses from www.tvreairworld.com they also provide free tech support to help you install them
Oct 27, 2012 | Samsung HC-P4752W 47" Rear Projection...
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
En7410 won't turn on
DONT WASTE YOUR TIME AND MONEY THE PCB(POWER CONTROL BOARD IS BAD YOU WILL BE BETTER OFF BUYING A NEW MONITOR)
IF you do find the power control board replacement and get it to work i think you would have better results spending the same amount of money on a new monitor with all new parts plus warranty
Jan 15, 2008 | Envision EN7410 17" LCD Monitor
Samsung B/W Observation System - Model# SSC-12
I have the same problem and I found out that a resistor went bad and then a capicator went bad.you must have them check and replcaced
Oct 26, 2007 | Samsung Weather Resistant Security Camera...
No display
I have repaired 3 Viewsonic VP211b monitors.
The power light comes on but there is in picture. In all three cases it was the same problem. It was a blown fuse on the inverter board.
1. The monitor must be opened: The black plastic back is pried off carefully. It is easy to damage or crack. This will expose the electronics.
2. Remove the metal covers: The power main board has a metal cover that is secured with 4 screws. When that cover is removed, you can then remove the cover over the inverter.
3. Remove the inverter: The inverter is held with 1 screw. There are a total of 6 pairs of wires to the fluorescent lights (3 on each side) that must be disconnected from the inverter and a there is a power and control cable to the main board that must be disconnected. The inverter should now be free.
4. Test the fuses: On the inverter there are two tiny surfaced mounted fuses, labeled F1 and F2. They are on either side of the power cable CN1. Either one can be blown. Test them both with an Ohmmeter.
These fuses are 1.5 mm long, 1.0 mm wide and 0.5 mm high (Case Style 1206). They have the letters FN printed on them. The N is for 2 Amps and the F is for Very Fast Blow.
I replaced them with the same fuse, except Fast Blow rather than Very Fast Blow. The replacement fuse has just the letter N. The FN was not available at the time and I felt the N would be close enough. The fuses were made by LittleFuse. They were purchased from Newark Electronics. Part number 64R8010.
Prior to acquiring the surface mount caps, I tested the inverter board by soldering a regular fuse across the blown fuse and putting the inverter back into the monitor. The monitor came back to life. Normally when there is a fuse blows, it is because there is a short someplace down stream. How ever the new fuses have held. Therefor I am assuming it was just faulty fuses.
With the new surface mounted fuses, the repaired boards were placed into monitors and they all worked.9486ec61-dd3d-4a22-bbc3-82b55a458b09.jpg00ad0ac3-9cf1-4fff-83ed-90d93e6a0e0a.jpg40cff7a9-f7c7-4904-aac3-eb656a117911.jpg0ee0c7e1-1e8a-4b07-936c-83557d5ddd2b.jpg3ccdb800-f497-41ee-b268-cad6a2330191.jpg4d8ec0f3-f0e3-4e06-bc47-791b2996f04b.jpg
Jun 02, 2007 | ViewSonic VP211b 21.3" LCD Monitor
Sylvania 6615LE LCD HDTV Logo
16 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
