Question about Acer AL2016W 20" LCD Monitor
Computer won't recognize monitor driver
I have an Acer 24" wide screen LCD monitor. (P241WA)
Everything works fine but is running on a default generic driver. My computer can't find this Acer. Because of this, the Acer software "eDisplay Management" won't work either.
I am running on XP in a HP Media Center PC (m7250n) with 3 gb ram. My graphics card drivers have been updated (ATI Radeon 300).
I do not have anything but USB and/or standard monitor cable hook ups on this computer, so DVI won't help.
  • preachie Dec 11, 2008
    When I commented about the USB I just meant it was a possible hookup. I am only connected by the VGA monitor cable. The monitor itself has all types of hookups available (VGA, DVI, HDMI).
    President:
  • 1,073 Answers
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Posted on Dec 11, 2008
Acer S232HL driver did not install I want it instead of the Generic PNP driver. Help please
Good for you Barb, in the future be aware the for display adapters you can simply remove them and you would be prompted to re-install a driver for it at reboot.
It will by default use a generic monitor driver so you just cancel out the install and then run the setup off the CD.
regards,
Mike
Oct 07, 2012 | Acer S232hlAbid 23 LED LCD Monitor 2 ms...
LCD Monitor isn't recognized
it is an issue with the LCD on your laptop as you get a fine display on external monitor
either get it repaired from a local technician
or get the LCD replaced
Jun 07, 2008 | Compaq Armada M700 Notebook
My laptop LCD screen is FUBAR and in order to use my computer I have hooked it up to an Envision 19" LCD Monitor. If I start Windows Vista in Normal mode , it does not recognize the Monitor. Pressing...
I would go ahead and boot into safe mode where you say it does work and then take a look. See how it detected it...ie look in device manager and see if it picked it up by it's true brand/type etc. Check the settings both of the display and on the envision itself. Check the resolution selection. It's probably picking it up as a lower res. but when it boots into reg windows may be trying to run at full res and perhaps that's what it won't do. Check to see what driver it's using. It may need the specific driver from envision and not the generic driver. It could also be a bad pin on the envision itself.
If you have another computer you can hook it up to, do that to make sure the envision is working. That way you can deduce which is the problem, the monitor or the setup in your laptop.
Jul 10, 2011 | Envision 19" Widescreen Flat Panel LCD...
I have tried all option on the Acer screen so the
The resolution is done at the PC video output setting, not at the monitor, you should set the PC video resolution to be at monitor native resolution: 1920 X 1200 @60Hz This will give the correct aspect ratio of your display.
Mar 26, 2010 | Acer X243W 24" TFT wide format screen 24...
Running with 2 monitors on a Windows 7 OS.. 2 exact brands / size. main monitor shows the correct driver. 2nd Monitor shows Generic PnP Monitor. How do I get 2nd to show the correct monitor? I tried...
You will need to go into Device Manager, and look at your Monitors listed. One probably lists as Acer AL2016W, the other one lists as Generic PnP Monitor. To fix this, open the Generic PNP Monitor (right click and go to properties). Then choose "Update Driver" button, Select "Browse my computer for driver software", then select "Let me pick from a list of device drivers on my computer".
You should automatically get a list for the Acer AL2016W option. Depending on how it's cabled up and connected, you ay either get Analog, Digital or DisplayPort (or HDMI if that model allows it). Choose the option that's relevant. Now your monitors should list properly.
Nov 30, 2017 | Acer AL2016W 20" LCD Monitor
Image doesnt fill the screen on new Acer H243H PC
you need to download the latest graphics driver: Go to acer website.
Jul 27, 2009 | Acer Aspire One AOA150-1405 Notebook
P223w
This is known as Dual-Link DVI, it is a requirement for many high resolution large wide screen LCD monitors. (WQXGA 2560 x 1600 resolutions and such) You are correct, you must ensure that the display adapter you are using supports Dual Link and you are using a 24 pin Dual Link DVI cable
http://en.wikipedia.org/wiki/Dual-link_DVI
Feb 05, 2009 | Acer P223Wwd LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Screen resolution
hi, try playing with the aspect ratio .. let me know
Dec 11, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL2016W 20" LCD Monitor Logo
420 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
