Question about Zanussi ZWF1430W Front Load Washer
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
10 min in to washing cycle the machine tripped out the electricity mains. when I turned the electricity back on the machine went on paused and I could not resume the program. I skipped program to the end to restart program. I switched the machine off and back on while it was still full of water. When I attempted a new cycle the machine will only flash and beep 5 times on the end light. We have drained the water and replaced the fuse but it still does the same. Please, please help us.
  • 17 Answers
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Posted on Dec 17, 2008
Zanussi machine washer. ZWF 1000M The wash button is red. The rinse button, spin button, and power botton is flashing red. This happened several minutes after tuning oN the 30 min cycle.
According to your description it is a failure E9- motor is not working. The temperature rises too high. The motor cut off for heat safeguard (Harness failure, PCB failure).
Dado
Apr 06, 2016 | Zanussi Washing Machines
Zanussi zwf 1437 starts cycle then stops midway. door light flashes. have to turn off machine at main switch to reset
This is a door lock fault, the lock is working initially but as the machine operates it fails, the only way to fix it is to replace the door lock assembly
Mar 07, 2012 | Zanussi Washing Machines
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
My problem is the machine makes a noise as if a piece of cardboard is rubbing at one particular point each revolution of the drum it has now become quite loud on my zanussi zwf 1632 w can anyone help ?
I may just be lucky or it might just be temporary but the fault has cleared on my zanussi zwf 1632 w. washing machine thanks for the offers of help if needed in future i will certainly contact FixYa."Bill 34"
Sep 19, 2009 | Washing Machines
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Zanussi zwf 1632 w
hi follow this Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
thank u.......................
Sep 12, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
715 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
