Question about Konica Cameras
I have an error code 10 flashing on display of my konica hexar rangefinder. In wich way I can repair it? And what it means?
  • 14 Answers
SOURCE: error code
This error msg appears when the speaker cord is shorted When the speaker output is in contact with the vehicle ground
Posted on Jan 29, 2006
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 168 Answers
SOURCE: konica 3135 error code 41
41-3 Error Code is an Optical return problem. The Scanner is not returning back to home position like it should.
A common problem with this model machine is a small black gear on the drive motor cracks or ovals out. If you can locate this gear, you can try placing a drop of super glue on it and see if it will hold. This works if the gear is ovaled out. If it is cracked or split then you will need to replace this gear.
Hope this helps a little.
Feel free to post another question if you need more help.
Good luck,
Mac =)
Posted on Jun 26, 2008
checkitright
  • 1362 Answers
SOURCE: Konica Minolta Copiers
F26 Toner density adjustment problem. This means machine is undertoned. To repair, replace developer and enter "47" mode. Press 51. Press print. Allow the machine to cycle until it stops. Some feel that you should disconnect the toner motor first. This ??? ?????? happens probably because either machine wasn't set up properly, or the customer kept on using the machine with the toner light on.
Posted on Aug 25, 2008
SOURCE: Xerox Doc12 10-386 error code
10-386 Error
Posted on Dec 01, 2008
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Error
er 6 corresponds for the chip to be reprogrammed
May 14, 2008 | Bushnell Yardage Pro 600 Rangefinder
HOW DO I FIX KYOCERA SUM ERROR CODE F010?
That service code refers to the flash dimm, which is on the main pwb assy (controller). You have to try upgrading the system firmware. If the upgrade procedure fails, then you have to replace the flash dimm.
Jul 25, 2014 | Kyocera Mita Office Equipment & Supplies
When i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Apr 09, 2013 | Konica Minolta Office Equipment & Supplies
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
NAND FLASH ROM ERROR IA CODE CHECK SUM display on my konica bizhub C10..
Have a Konica Minolta Tech come out and re-flash the machine firm ware, can not be done with out access to a secure web site to down load the firmware
Oct 26, 2010 | Konica Office Equipment & Supplies
E31 error message on screen of pinseeker 1500 bushnell
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. "lob" means low battery condition. In these rangefinders "lob" will show up with a new non-alkaline battery installed. Non-alkaline batteries just don't generate enough current for the laser to operate properly. Reprogramming costs about 20 bucks, if it needs an alignment (won't hit a flag or target at 200+ yards >50 bucks<) Oily looking spots in the display are from not using the eyepiece cap and direct sunlight damages the LCD. (15bucks) The address for repair is:
Bushnell Repair Center
8500 Marshall Drive
Lenexa, KS 66214
800.423.3537
Send a problem statement, your phone number, and $10 for return shipping.
Good Luck to you!!!!!
Mr Tech Geek
don't forget to vote/rate me....
Jul 03, 2009 | Bushnell Optics
EEE error on my Konica Hexar AF
If you are using Windows xp , download the UVC driver update from http://www.microsoft.com/downloads/deta … laylang=en.
If that is not enough follow the threads below about EEE and USB drivers.
EeeUser ASUS Eee PC Forum
EeeUser ASUS Eee PC Forum / Camera drivers
Nov 25, 2008 | Konica Hexar Silver 35mm Point and Shoot...
Focusing ring looseness on 50/1.2 M-Hexanon
did you see any rubber gasket on the ring.. this could be the one turn out to be loosen,
did you dropped or any kind of incident happened on the lens.
Nov 06, 2008 | Cameras
Error code er6
Take the nice cover and neck strap off rangefinder to use on another item. Next use the rangefinder for hammer. boat anchor, etc. Seriously though the problem occurs often in the Bushnell rangefinders and it cost more to fix than to replace with a better brand. A $179.00 original cost rangefinder cost $10.00 to ship back to Bushnell and another $235.00 for repair of a non specified problem for a grand total of $245.00. I consider this a rip off from Bushnell.
Dec 09, 2007 | Bushnell Yardage Pro 600 Rangefinder
Cameras Logo
Top Konica Cameras Experts
myxelpyxel
Level 1 Expert
Are you a Konica Camera Expert? Answer questions, earn points and help others
