Question about Lexmark Office Equipment & Supplies
I have a lexmark x4850, it's connection broke altogether today, so I uninstalled it since trying to re-install it, it says I'm connected successfully, but, when I go into the Printer File, there's no icon/s listed except the Add Printer??
  • cobrette9 Dec 11, 2008
    It's telling Me - It's failed to create pring object for lexmark 4800 series. Driver is not compatible with a policy enabled on My computer that blocks NT 4.0 drivers. (1930)
    Can you help..?..
  • drumweezer Jan 21, 2009
    I have tried installing the driver through cd installation. I have also tried installing the driver that is on the Lexmark website. I have had no success. It works on all my other computers, except one, which is running on Vista. I also have another computer with Vista that did not have this problem. Does anyone know of a solution?
  • 2,110 Answers
Posted on Dec 11, 2008
  • Sibananda Jena
    Sibananda Jena Dec 12, 2008
    Thats fine but this is the right driver for ur printer..So why did u gave me In Appropriate rating???????????
Downloading C/D software from laptop
You can try downloading and installing the printer driver from the following link. Click on one of the external mirrors to start download:
Try and run another disc in your CD drive to make sure that it's working.
Mar 28, 2012 | Toshiba Computers & Internet
My Lexmark x4850 has stopped prin?t the computer. What is wrongting . Sometimes it will print when I restar
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark Wireless X4850 All-In-One Inkjet...
How can I install my lexmark x4850 printer on a new computer without the installation CD?
You can download the Lexmark X4850 driver by visiting the Lexmark website at Select your operating system, download and execute the file. Follow the instructions on your computer screen.
May 30, 2011 | Lexmark X4270 All-In-One InkJet Printer
Cannot use Lexmark X4850 printer without installation disc.
Lexmark, as all major manufacturers, has the installation CD content in downloadable form on their website.
Nov 03, 2009 | Office Equipment & Supplies
Can't connect wirelessly to a lexmark x4850
  1. write down the MAC address of your Lexmark,
  2. log into the router and reserve an IP address with that MAC
  3. Setup the Wireless parameters (SSID, Encryption to WPA or WPA2 Personal, assign a Pass Phrase you can remember. Then save the config and reset the router.
  4. on the Lexmark console, navigate to wireless settings and configure with the matching parameters as set in step 3.
  5. If the wireless connection is matched and connected, open up Internet Browser and type in the IP address in Step 2
  6. It should have a web-interface allowing you to customize it.
  7. Install the printer with the driver disc but should now look for a Networked option. or simply Add or Change the Port of your existing Printer's Properties.
Jun 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
LexmarLk X4850 fax wireless set-up
Printing: since Lexmark say you can either connect wirelessly or wired and not both, you must either connect your daughter's machine to the hub by wire or yourself to the printer wirelessly.
Fax: this will need a phone line.
May 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4850 wireless how to make it find the wireless network. I've had this printer working with my Vista laptop till recently; then I moved to another area, configured my new home network and Internet...
If the printer itself is wireless, it does not need to recognize your wireless computer network. Call Lexmark to walk you through proper installation. Lexmark's manuals are not adequate regarding setup, in my opinion.
May 07, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark X4850 Wireless wont connect
Had a similar problem with my router, which was a 2WIRE router (furnished by AT&T - I have Uverse). Fixed it by going to the router's GUI (mine is, click on "View the home network". On the right side of the resulting screen, there is a section titled "wireless settings". Under that, click on "edit settings". Enter the login information (the default password is on a tag on the router). The next screen is "Configure the Wireless Network". Scroll down to the bottom and click on "Rescan". When I did this, my X4850 miraculously connected and started working.
Rick from Austin
Aug 16, 2008 | Lexmark Wireless X4850 All-In-One Inkjet...
163 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
