Question about GigaFast Ethernet WF748-UI (WF748UI) 802.11g/b Wireless Adapter
Problem connecting to the internet using wireless usb adapter
I am trying to use a wireless usb adapter on my kids pc to connect to dsl but am have problems connect to the internet. The indicators on the wireless adapter indicate a signal strenght of 100% and link quality of 94% and link status as connected to access point but when i click on the internet explorer i get the cannot display page message. I tried contacting qwest who is my dsl provider and they said they could not help me with a third party product. Can you help me?
  • Denice Aragon Mar 06, 2007
    I tried to run the program and also delete temp files and it still doesn't work. Do you have anymore suggestions?
Thank you for your expert advise I was able to successfully sign on to the itnernet. You're awsome
Posted on Mar 09, 2007
    President:
  • 2,961 Answers
Run this programme, then if necassary clear temp files in tools in your explorer. Start> Run then type ipconfig /flushdns then press enter.(note the gap between ipconfig and the /).
Posted on Mar 05, 2007
  • andrew pester
    andrew pester Mar 06, 2007
    Go to control panel and then network connections and right click on the properties of your network adapter and then TCP/IP line and click properties again and check that 'Obtain IP address automatically' is checked.
    If you know how to get into your routers settings via your internet browser (normally 192.168.2.1 or similair depending on model) and make sure enable DHCP is set so as to give your adapter an ip address.
    Also check that the router if it's a 125mbps one is only set at 54mbps as your reciever may only recieve at that speed.
    Make sure also that you have'nt got a programme hijacking your home page or search page.
    Go to tools in internet explorer, then manage add ons and click programmes currently running internet explorer and look for suspicious search tool bars that you have not indtalled and click dissable.
Xbox 360
Best way to use your xbox 360 is with a stable internet connection wired to a router using dsl or fiber connection.
May 14, 2013 | INTELLINET Wireless 300N USB Adapter...
Where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
I have a usb wireless adaptor why cannot connect to the internet
look its an ADAPTER an adapter ADAPTS to the internet BUT for the internet you neeed WIFI.. BY a ROUTER Or by your DSL set up the wifi and your ADAPTER WILL pick up your WIFI once they ADAPT you can connect to the internet.. RATTTE
Jul 22, 2010 | Nintendo Wii Console
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
How do I hook my wireless usb netopia chip in order to sign on the internet
You ned to contact an Internet Service Provider to determine if your USB wireless adapter is compatible with their service.
Read this info for an idea on how to connect to the Internet :-
There several ways to connect to the Internet.
1. You can use a cable or DSL modem and connect this modem to the laptop with a LAN cable.
2. You can use a wireless router with a cable or DSL modem and connect to the wireless router using a wireless card (a PCMCIA wireless card or the laptop may have a built-in wireless card). This wireless card can also be used in WiFi locations such as the airport, McDonalds and Starbucks etc.
3. You can use an USB G3 wireless adapter. This type of device uses the G3 mobile network and may not give you Internet coverage in some locations.
All these require an Internet Service Provider and the costs vary widely depending upon the various plans they offer. Check the ISP in your area and compare the plans and cost of their plans and pick the one that best suits your needs.
Sep 11, 2009 | Computers & Internet
I have an older HP laptop with no wireless capability. We have DSL with the wireless router connected to our desktop. The only way I can access the internet is by putting in the AT&T air card. I don't want...
You can connect to the Internet using your DSL wireless router by several methods.
1. If your HP has a LAN port the you can connect to your wireless router with a LAN cable (provided you have a spare LAN port on the router.
2. You can use a USB wireless adapter to connect to the wireless router.
3. You can use a PCMCIA wireless card to connect to the wireless router.
Both the wireless USB and PCMCIA wireless adapter are approx. $50, my preference is to use a PCMCIA adapter, it leaves the USB port free for other devices,such as USB memory sticks, especially if the laptop has only one USB port.
Jan 17, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Usb adapter
if the router is already set up the usb dongle software will need to be used to connect to the router to allow a connection without the need for a cable as the dongle will see the wireless signal
Aug 31, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Internet connection
1. Change channel used by Access Point
2. Try to set up router to different security, this problems may happens for WPA authentication.
Mar 25, 2008 | D-Link Wireless
GigaFast Ethernet WF748-UI (WF748UI) 802.11g/b Wireless Adapter Logo
151 people viewed this question
Top GigaFast Ethernet Computers & Internet Experts
Prashant M
Prashant M
WelderArc
Are you a GigaFast Ethernet Computer and Internet Expert? Answer questions, earn points and help others
