Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Rangemaster 110 grill flame.
The flame on the grill is very low, as low gas pressure. It will light, but then starts to splutter, and goes out.
What parts are needed to fix this problem
  • rogerandrose Jan 05, 2009
    Same problem as other correspondent. Grill seems blocked. Any ideas please.
  • Anonymous Mar 16, 2014
    I have a rangemaster110 same old problem grill lights then splutters and goes out? I have replaced the regulator still the same! where do I regulate the air flow they talk about please. Kind regards Jamie
    Habit-Forming:
  • 171 Answers
To find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Posted on Dec 12, 2008
Flame keeps going out on ring
clean all of the holes the flames come ut f with a small brush t culd be clogged also lift range hod and look under it by the lines see that nothing is loose or obstructing the gas line
Dec 19, 2014 | Rangemaster 110 (Gas) Kitchen Range
The ovens in the rangemaster will not work as the timer is not working. The timer will not flash and when it does decide to flash it goes right back to non flashing zero. Can i use the cooker without...
Try putting your grill on low for 30 minutes to one hour the clock should start to flash then leave to flash for five minutes after which press reset. It worked for me on my rangemaster 110 (gas)
May 15, 2011 | Rangemaster 110 (Gas) Kitchen Range
I have a Rangemaster Leisure 110 the left hand oven lights up, but the flame is very low and will not go to maximum.
common problem, there is a device in the oven called a solenoid/ff device these are safety devices and fail after a few years. replacements can be obtained from main stockist Gas On spares on 0121-585-7799
Apr 04, 2011 | Rangemaster 110 (Gas) Kitchen Range
I have a leisure rangemaster 110 double gas oven the left oven stays low i have tried cleaning jets but this has no effect can you suggest a cause
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Dec 18, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster gas grill - little or no gas pressure
you can phone rangemaster helpline on 08707 895 107 spare parts or tech team.
Feb 26, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 gas grill flame
your burners are not burning good because they need to be cleaned and the loud popping noise is the gas burning in the ventury until it burns it self out its a very common thing
Feb 19, 2009 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Low flame
the best way is to get a gas fitter to check the millibars coming through the pipe. it should be 20 miliibars at the meter or more and not less than 19millibars at the cooker. if its less it needs bigger pipe. simple test to do. if its wrong at the meter the gas supplier must turn it up.
Dec 04, 2008 | Rangemaster 110 (Gas) Kitchen Range
Gas oven
Its the flame failure device faulty (FFD)
Nov 30, 2008 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110
Reading the user manual, it states that the flame initially comes on low, until it is "sensed" by the flame sensing device. This to me sounds suspiciously like the flame isn't being sensed and so never gets increased to the normal level.
I've not had time for a proper look at it.... but from a quick glance this morning this looked like a "flame rectifier" probe next to my burner (as we commonly use in boilers to sense if the gas burner is lit). This is just a metal probe. They send a high-ish AC voltage signal (Sine wave) from it, through the flame, to the earthed metal case. The flame acts like a diode (yes it really does work !) and simple electronics detects the change in the applied signal (rectified) due to the flame. I know from personal experience they (the probes) get coated with crud (carbon, etc) and need a good clean. I suggest you try cleaning both it and the metal area opposite it. If necessary the probes metal tip could be GENTLY rubbed with very fine Emmery cloth, etc, if badly coated.
Other than that, if it is sensing the flame, then it must be the gas control device (solenoid valve ?) that is jammed, blocked or just defective.
Simples......
Dec 18, 2007 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
644 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
