AFTER TRY TO UN LOCK BLACK BERRY CURVE 9300 THE SCROLL STOP MOVING WHAT CAN I DO
Alice, read follow :
identifying problem : this is sound me hardware problem,on scroll area; Causes :normally this happen by water damage (because of wet finger touching), Solution :
Clean with alcohol the scroll area and keypad area on board, and let it dry for 4hours, it will start working.
Material need :
screw drivers tools for device, Brush,and alcohol.
Notes:
if you don't know how to assembly and dissembly the device search on you tube.com but if are you not able to do this at home, please don't try without supervision of technician,give some official repairer to fix for you.
SOURCE: the track ball does not move up only down when strolling
Try putting a small drop of kitchen de-greaser (Mr Muscle etc) on your finger and rolling the ball with that finger. Do not pour it on to the device, just a small amount on your finger should cure it.
Works for me every time.
David
www.OutdoorInbox.com
SOURCE: my blackberry curve freezes on reset with the
Complete one of the following, depending on the network on which the BlackBerry smartphone is operating.
If its not working then you need to Re-install the Software
SOURCE: my keyboard backlight for blackberry
I found out on here how to fix it. You take the battery out, while the phone is turned on, leave it for 30 secs then put it back in. So far it seems to be working.
SOURCE: I forgot my password for
You have to reset your mobile..This can be done by codes..I found the security unlocking service at Prounlocking.com .Through this you can reset your mobile easily..
SOURCE: where is the reset button for a blackberry curve
blackbrry 8520 doesn'thave the reset button.ID you stuck somewhere you can just remove battery and put it back and restart your phone. if you wants to do hard reset then go to settings.thanks
