Question about Xerox FaxCentre F110 Plain Paper Laser
CHECK PAPER Sir, we have faxcentre123 model & we are facing one problem ie check paper. It prints same paper every time from memory. so we are not able to get incoming fax. pls suggest how do we solve this problem?
    Problem Solver:
  • 11 Answers
Nah thats not the issue. the issue you are having, is that you need to reset the memory. I am having the same issue. i will try to post once I find the answer
Posted on Mar 18, 2010
    Genius:
  • 2,120 Answers
Unplug the power cord for 10 seconds
You must contact the sending party and tell them to STOP if the above does not fix the problem.
Posted on Jan 24, 2009
I am new at this service. I emailed in a question yesterday and you asked for more information. I have just recently installed a new hard drive on my computer. In using Quickbooks, I am not able to...
You'll need to go into your printer's preferences when you print from quickbooks by clicking "Properties" in the print dialog. Then search through your paper sizes to find one that is check sized. If you cannot find it, add another paper size that is 6? x 3.75?, which is the size of a check. You might want to cut out a few check-sized pieces of paper to test your settings/margins on, so you're not ruining checks.
Jun 15, 2011 | Computers & Internet
Feel like an idiot...does the paper load with the print facing downward or upward?
You didn't say what brand and model printer you have so I can't look up a manual and check it for you. But if you don't want to waste a sheet of good stationery or a valuable form (like checks), make a test sheet. Take a plain sheet of paper and mark it along the top edge. Or use a photocopy of the form as a test sheet. Put the test sheet into the printer and print something on it. From the result you'll know how to feed the sheets in the future.
Mar 31, 2011 | Office Equipment & Supplies
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
Rollers won't pick up photo paper.
Hi I would suggest you to try once again by putting the shiny side up and print it again, some time even if the pages get stick with each other than also the printer wont take paper in. so try one more time and do reply if you still have the same problem or nay other.
Naiven.
May 31, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Printer says to re-insert paper face down.
You must have the default printer settings changed to "double-sided" printingor "print on Both sides".
Check in your printer properties: 'Right click' the printer icon. Select "properties", "Printing preferences", "finishing", un-check "print on both sides" (these options vary slightly by printer model, so just check around on the different buttons).
That's my best guess. :)
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Ip6700d won't print
Dear sir arthur,
Paper feed problem is usually caused by broken sheet feeder unit. But if you can print nozzle check pattern successfully it seems that paper cam sensor broken so it cannot reach paper end properly.Rarely, faulty paper feed sensor may cause the same problem.
Regards,
Nov 30, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Okic3200n lazer jet printer
Best results will be if the paper you are using is designed for use in this machine and you print with the driver knowing paper type and using a direct flat paper path
Use The bypass tray (and you can also use face up delivery tray ) and make sure you tell printer what paper type it is using ie control panel, printers, preferences, paper type set to photo/gloosy or even card stock if it is thick.
Ensure feed rollers are clean, and paper is good quality
Dec 23, 2007 | OKI C3200n Led Printer
Xerox FaxCentre F110 Plain Paper Laser Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
