Question about Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 p
When it comes to the water rinse or spin it does not drain out. Instead it comes out from the door. Ive seen the rubber on the inside of the door bent over, maybe that is why the water is coming from the door. But i think the problem started when i attempted to wash the Dogs Blanket. Hes quite a hairy dog. I phoned a plumber but he was miles to e
Expensive for me. £160 an hour. Could you please help.Yours Hopefully. Derek/Paula
  • Hotpoint Master
  • 3,463 Answers
If you washed a dog blanket, then that is probably the cause of your problem.
The bits off it will have blocked the pump or filter.
What you need to do is the following.
Remove the lower back panel of the washer.
Remove the large black hose that is fastened to the bottom of the tub.be careful, because you might find quite a lot of water comes out, have a bowl or bucket handy to catch the water.
Inside the hose you will find the filter, remove and clean, make sure that the pump is clean also..
On re-assembly, make sure that you get the hose on properly or you will have flood.
Take particular note of where the hose was fastened on the bottom of the tub, and make sure you have the filter and ball in properly..
This should solve your problem.
Come back to me if you need any further help.
Plz rate my solution.
Thanks.
Posted on Dec 11, 2008
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 water level switch loaction?
Should be located under the lid near the top edge, round shape with a tube going to the bottom of it and wires in the front. To remove from the frame turn the whole thing 90 degrees as fitted with with rectangular fitting on rear.
Jan 21, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 stopped spinning is the motor /brushes in top or bottom of casing had other hotpoints and the brushes seem to go evry 5 yrs or so? are they as easy to change as the older models?
it is as easy as the older modles but the motor is at the bottom and you have to take out the motor to replace the carbon brushes hope this helped.
Aug 29, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint Ultima WF865
i have a wf 860p hotpoint washing machine and it has come up with an error code of f 08 can you tell what this error is and how i can fix it.
many thanks
lynette
Oct 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA76 Ultima 6kg
either you got a clog behind the drum or a clog in the draining tube behind the washer i would call sears or where you got it to get someone out there to check it out or if you got the manual of the washer and specs to see maintenance tasks that it requires if you know the make and modal i could get that for you ..
djkb
Jun 26, 2008 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 Front Load Washer Logo
292 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
