Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG LD12AW2 Dishwasher overflowing
Have cleaned out the gunk in the small water reservoir that links to the pressure switch and cleaned the pressure swithc, but no luck. Still overflow. Whe i watch the water reservoir fill after going through the drain cycle first, it seems like the reservoir is only getting a small amount of water in it and then stopping - no way to trigger the pressure switch to do its job. What would be causing this?
  • Steveo808 Apr 29, 2009
    Hey there
    You have to pardon my ignorance on this one but i am assuming that the water inlet port is the white plastic fitting about 1/3 of the way up on the left hand side of the machine?
    I am having the same problem and can you give me a bit of an estimate on what it should cost to get it fixed ?
    I am in Perth and if you have a contact here I would happily use them because i think you give the free advice here is very commendable .....
    Thanks
    Steve
  • 423 Answers
On the LG LD-12AW2 model, there is a float assembly just behind the wall where the water inlet port is located inside the unit.
When that float (or the micro-switch inside it) fails, water will continue to flow in without stopping . That causes the overflowing.
Post back here if you are looking for more specific guidance.
Good Luck!
Posted on Apr 11, 2009
My Maytag dishwaher is three years old. It will not start. The only button that will work is the cycle slection.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MDBH945AWW&siteCd=MT_EN_US&userType=Servicer
Above is your link for your manuals, use these along with the DIY self help repair website below, to troubleshoot and hopefully repair the problem.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Now this fix below may not work, but it is always worth a try, if it fits the criteria. Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Jul 05, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Tip
So your Dishwasher sits and "Humming" cannot turn off, no response.
on Mar 27, 2010 | Dishwashers
Dishwasher starts to work but after 30 seconds stops and two lights start flashing on pannel
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.Service manual below, if the above doesn't help. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Jun 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher fills, but won't start running. it just sits full of water and just hums.
Apr 14, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
Inlet drain light on and no drainage
Apr 02, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher pumps even with power off
Mar 28, 2010 | Viking 24 in. Professional Series VUD040...
Bosch SMS4012GB dishwasher. Refused to fill. Found tray full of water in base of unit. Mopped up water about 2 litres. Machine works but lower reservoir on the side of the machine with float switch...
An electric switch activated by air pressure. This device detects air pressure exerted on it through a flexible tube connecting it to part of a water tub.
When activated, this switch then opens an electrical circuit stopping further filling of water into the machine.. May also be called a PRESSURE SWITCH. if not activated definately it will cause overflow.
Check the wire harness to the pressure switch. or tap your float switch with finger tips may be it get stacked. if nothin happen replace the pressure switch.
Rate my solution if useful.
Prince P
Jul 24, 2008 | Dishwashers
Too much water where is fill switch
the fill switch is actually a pressure swith located at the bottom front of the d/w.
take care.
Jul 20, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD12AW2 leaking
The fill switch may be contaminated with soap or debris that makes it heavier and makes it float lower in the water which means more water is required to trip it. Try moving it manually and see if it is hard to move at the top of its travel.
Oct 28, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
818 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
