Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Using a HDD Caddy!
The screen on my laptop is no longer working and a friend advised me to purchase a HDD Caddy and transfer all my documents, pictures and music. The problem is i've never done anything like this in my life before and don't even know where to start....!!!!!!!
Please help me. I don't have a lot of money to spend on this, so don't really want to hand it in to a repair shop.
    President:
  • 1,073 Answers
Hi John!
I asume that you have that caddy, and its connected by USB?
Well, since your screen is black on your laptop you need to connect another screen by the VGA port on your laptop. Now start up your laptop, hopfully the graphics on yout motherboard is working and the screen lights up.
Now connect the caddy in a usb-port, windows will now find it and install it since its connected to an usb-port.
When the caddy is anstalled you can use it, you will find it under "My Computer"
Now you are redy to move all the files you want.
Select the file you want to move, COPY them, DO NOT cut them, if you cut them and something goes wrong you can loose them, by copy them they still are on your laptop. Copy the files, go to your HDD Caddy, open it, and paste the files. The files will now be copyed from your laptop to your HDD Caddy.
Good luck to you
If you find my answer helpful, dont forget to vote
Posted on Dec 11, 2008
How do I transfer data from one computer to another if the computer will not turn on?
Place the hdd from the faulty computer in a usb caddy. Connect the caddy to your good computer and browse/copy the files you want.
Feb 09, 2015 | Computers & Internet
I have a dell latitude windows 2000 C600/C500,when
If you require just your data, as it seems the system has crashed, purchase a usb hdd caddy. Remove the hdd from the old laptop, fit it to the usb caddy and copy your data to another pc.
Win2000 is totally unsupported now.
Sep 28, 2014 | Computers & Internet
Wpd file system problem
this could possible be the caddy take the HDD out of the caddy and plug into PC if HDD is picked up buy new caddy if HDD picked up but with faults use recovery software like recurrva if you plug it in and it does nothing then the HDD is kaput
Jan 12, 2014 | Verbatim EACH Drive, USB, 320GB, 2.5 in.,...
My laptop cannot detect my hard drive. It no longer vibrates and the light doesn't blink anymore.
the drive could be potentially corrupt.
plug in your HDD and run recurrva and try to recover files if you cant do that remove the HDD from the caddy and plug into a PC and test if you can access your files if not reformat by right clicking on the drive in my computer (ntfs is recommended) you will loose all data but you may be able to recover your HDD
Jan 04, 2014 | Toshiba 500GB STORE ALU2 PORTABLE USB2.0...
Toshiba satellite u400 hdd caddy adapter
Try to update your bios, so that you can boot in the proper order.
Apr 01, 2012 | Toshiba Satellite Pro U400-S1001X Notebook
System keeps freezing NO TASK MANGER OR POINTER OR KEYBOARD, also event viewer shows no sign
It could be that your Hard Drive is almost gone, or, that the system file is corrupt (but you would get a system error with this, pls advise if you do). In the case that your HDD is dying, I would recommend that you try and backup all your data asap to an external USB Hard Drive.
If you do happen to have another working computer around you can try this, but first you need the following:
1 external USB Hard Drive case that matches your PC Hard Drive fitting, ie. IDE or SATA.
2. A Windows XP cd with serial key.
If you do, then carefully disconnect all power to the problem PC, and carefully remove the Hard Drive.
Open your external USB drive case, and carefully remove the HDD, be careful not to drop any of the HDD - treat it with care.
Now insert the problem HDD into the fitting/connection that is either IDE or SATA, matching your case's fitting.
Close the case, dont have to insert the screws at this point, and hook it up to your spare working pc.
It should pick up on the screen as an external USB drive.
First, scan it for any viruses and clean it if any picks up.
Now locate all your data from Documents and Settings/Username/Desktop and My Documents and Favourites too.
Copy these files to your spare PC's Desktop with a New folder created and labeled.
After you transfered all your data, then disconnect from working PC, remove case of external usb drive, remove the HDD of the problem PC and insert it back into the PC body.
Insert the WinXP cd into the CD ROM drive and wait for it to boot from CD, then attempt a repair. Else, reinstall XP and follow the instructions on the screen - they're user friendly, and dont be scared:)
Jan 27, 2010 | Acer Aspire One PC Notebook
I need to buy a CF-18 HDD caddy and HDD where can I find one
Hello there:
Here is a couple of links for this for you to consider
I know that ebay has them but here is a couple of diffferent places for you to look at
  1. Hard drive for Panasonic cf18 - TabletPCBuzz - The Best Place to ... 3 posts - 3 authors - Last post: Aug 11Hard drive for Panasonic cf18 General Tablet PC Discussion. ... The ruggedness comes from the drive cage/caddy, not the drive itself. ...
    www.tabletpcbuzz.com › ... › General Tablet PC Discussion - Cached - Similar
  2. Replacement HDD for Toughbook CF-18 - CNET Miscellaneous laptop ... 7 posts - 2 authors - Last post: Nov 6, 2007... HDD for Toughbook CF-18 - Get tips and advice on this topic, ... to purchase is a caddy (shopping for a good price), HDD,(naturally, ...
    forums.cnet.com/5208-7587_102-0.html?threadID=270788 - Cached - Similar
Dec 16, 2009 | Panasonic Toughbook-18 Tablet PC
I got this really old HP Pavillion ZD7260us Laptop a friend left it to me with no HDD and no memory.So i went to buy a DDR PC270 512mb SO DIMM memory and an 80gig IDE Hard Drive. So i tried to install it...
try plugging a standard pc keyboard into the ps2 slot ,if it has one, if not use a usb keyboard. That should tell you if the keyboard is malfunctioning. As for using the hard drive with no caddy it should be fine as long as you pad it it securely, to stop it being knocked about etc when moving the laptop. Also you will need to enter the bios and set ideo 0(the hard drive) to auto detect. As it is more than likely detecting the old hard drive in the bios settings not the new one?
Oct 28, 2009 | Computers & Internet
I have windows vista just had a new hard drive installed the data off the old drive has been put onto an hdd caddy how do I load it back onto the new hard drive of my computer, the caddy is a plug in via a...
When you insert the usb cable from the caddy into a USB port on your notebook, Vista will automatically recognize it and open a dialog box. Choose to view files and folders.
Open another Window using Explorer and resize it so you can see the contents of your C: drive.
Then simply drag your files and folders from the caddy to the C: drive where you want them.
Remember that transferring program files will NOT help you as many of the files needed to run a program are located in other folders such as yours Windows directory. You will need to reinstall any software you wish to use.
This method is strictly for data transfer, as an example all your pictures, documents, spreadsheets, etc.
Sep 24, 2009 | Dell Studio 15 Laptop
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
226 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
