Question about Dell PowerEdge 2600 Server
Adding DVD to Poweredge 2600
Steve - how do i add a dvd burner to a poweredge server using a 3 port sata & 1 Port IDE PCI card? where do I get the power from for the new drives
    Novelist:
  • 159 Answers
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
Posted on Feb 09, 2009
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
What type of nic to add
Cannot be PCIe, as they are not supported - PCI or PCI-X. Check the slots, you may only be able to use 3.3/5V cards.
And as a sidenote ... the PowerEdge 2600 does not support x64 Operating Systems and does not support hardware-assisted virtualization (VT on Intel processors), so you will be limited on which VM solutions you can use.
Mar 06, 2010 | Dell PowerEdge 2600 Server
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
USB ports appear to not be working. Any clues?
Go to setup turn on the USB 1.1
The USB port is turned off for security reasons;
You may consider adding a 4 port USB 2.0 adaptor card my server has Both I use the onboard USB 1.1 for external hard drive and mouse
Nov 19, 2009 | Dell PowerEdge 4600 Server
I want to add a sound card into the PCI Slot, but already have a USB card in. Is there an extender or Riser that allows the use of two cards? The ports within the cards need to accessed from the slots on...
I put in a sound blaster sond card in my Dell 600cs from Wal-mart takes the newer soundblaster card is notched to work with 64 bit slots i have a pair of Poweredge 600cs nice workstations one is dedicated for data recovery. sound blaster live will not work
Hope this helps same way for adding nic cars use server cars have the noch to fit.
Oct 12, 2009 | Dell PowerEdge 600SC (Refurbished)...
Dell Poweredge 2650 - How do I disable RAC
If this is a security concern then there is nothing to be concerned about so long as you do not plug a network cable into the RAC.
Otherwise, if it is an add-in card just remove it.
If you can't remove it there should be a way of accessing it when the server starts up. You should be able to go into the configuration and disable its functions.
I hope this helps.
Jul 05, 2009 | Dell PowerEdge 2600 Server
Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
Jun 05, 2009 | Dell PowerEdge 4600 Server
Drive Options with a Dell Poweredge 2600
I would definitively not recommend to remove the backplates, unless you want to ask for serious trouble with your system.
I would install a PCI SATA adapter card (one like these) and connect your SATA drives to it.
May 27, 2009 | Dell PowerEdge 2600 Server
CDROM and with a bootable CD is not been detected
Same solution as posted before if you need to boot from a DVD: take a Dell laptop CD/DVD combo drive, remove the screws and all and exchange the PowerVault CD drive unit with it. Same internal connector. Can't remember what model I stuck in, but I had to keep the front panel of the drive since it was slightly different, I probably could have glued it, but.... That's a server machine no one is ever going to see but me! :)
That also gave me a CD-Burner which is a decent addition in case you need to quickly burn a CD/make a backup/boot disk (like a "ultimate Windows CD" boot to fix anything that could go wrong).
Nov 29, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 2600 Server Logo
1,231 people viewed this question
Alun Cox
