Question about HP Compaq d530 PC Desktop
Steps to system reboot
Hellow how do i do a system reboot i have a compaq desktop its a bit old but still ok just keep getting a lot of popups like a virus so i need to system reboot. My popup blocker and firewall is on
  • 2,110 Answers
Press ctrl+alt+del
then in the task manager click shutdown
Posted on Dec 11, 2008
I got a copy of eGames Lexicon Word Challenge from the ebay marketplace in the mail today, but it won't run on my computer -- says that since my computer is 64-bit I have to get a 64-bit version from...
Follow this sloution:
- Open the CD contents in file explorer.
- Right-click on the Setup for the game.
- From the popup, select Run as Administrator.
- Following the prompts from that point as normal for the game.
Good luck, Jopica123
May 16, 2011 | E-Games Lexicon Word Challenge for Windows
No statup sound in system
Restore the Startup Sound in Windows 7 If you decide that you want the Windows Startup back on your computer, just follow the steps explained above, but this time, check the "Play Windows Startup Sound" checkbox and click OK. The change is saved immediately, and turns back on this sound for the next time you reboot your PC!
Sep 26, 2010 | HP Compaq dx6100 PC Desktop
Laptop keeps restarting
  1. See if you can start in Safe Mode (hit F8 before Windows loads - best way is to keep tapping F8 after you power it on. You should get a menu with "start in Safe Mode" as an option.
  2. Once booted in safe mode go to Control Panel, System, Advanced, ;Startup and recovery'.
  3. Click the Settings button and remove the tick from the "Automatically Restart" box.
  4. Click all the OK's to get back to Control Panel.
  5. Reboot as normal and the system should display an error code. Post that error code here and we can have a look at it.
Sep 07, 2009 | Compaq Presario 5000 PC Desktop
Stuck on Compaq Screen and keyboard dead
I would take the cover off and reseat the memory, video card, and processor. Make sure your fan(s) are working too, and blow any dust out of it if you see a lot of build up.
Dec 25, 2008 | HP Compaq Presario SR1720NX (EL435AA) PC...
Compac Presario DeskTop
Systems usually come with a large amount of "startup" items - each of them takes up memory and slows down the computer; sometimes significantly. By performing the steps below, it does not remove the program from your computer; it merely keeps it from "pre-loading" when your computer starts up. Some things, such as your antivirus software, drivers and "easy button" type software that runs the extra buttons on a keyboard, for example, should not be removed from startup.
Go to Control Panel, turn on the Classic View and then go to Administrative Tools. Go into "System Configuration".
You will see several tabs: General, Boot, Services, Startup and Tools.
Click on the Startup tab.
You can choose to disable unnecessary programs but as I stated in the beginning, make sure you don't disable any important system components or drivers. If you are not sure which ones you can disable, it is better to consult someone knowledgeable with a list (the list is different on every computer) and let them help you.
If you know which programs you don't need to start when Windows starts, just uncheck the box on the left side of each program you want to disable. When you are finished, click OK.
A new window will appear and ask if you want to restart the computer. Go ahead and restart now.
After the reboot, you will see a balloon popup showing "Windows has blocked some startup programs".
In order to remove this, click the icon in the system tray and select "Run blocked program" and then click on System Configuration Utility. You will see another window with a warning, once again, that you have changed the way Windows starts. Select "Don't show this message or start System Configuration when Windows starts" and then click OK.
You may be extremely surprised at how much faster and more smooth your system will run without the extra load on your memory. If you would like to re-enable any of the items, just follow the same procedure, and place the checkmark back in the box for items you would like to re-enable for startup.
Dec 12, 2008 | Compaq Presario 5000 PC Desktop
Sound problems and very slow starting up
Click on Start
Click on Run
Type "MSCONFIG" Click OK
Click on Startup Tab.
Leave CCAPP,IGFXTRAY,KBD,HCM checked and Uncheck rest all of them.
Click on Apply and ok
it will ask you to restart, so restart the Computer.
Second Step:-
Click on Start
Click on Run Type %Temp% and click ok
A window is going to POPup
Delete all the files from the Window or as much as you can.
Third Step:-
Click on Start
Click on Run
Type "Prefetch" and click ok
A window will popup
Fourth Step:-
Click on Start
Right Click on My computer
Click on Properties
click on Advanced Tab
Click on Setting under Performance
A window for Performance Options Will Popup
Click on Advance again
Click on Change Under Virtual memory
A virtual memory Window will Popup
click and Check the Custom Size button and
Initial Size :- 1536
Maximum Size :- 3072
Click on Set
click Ok on all the windows and restart the Computer again.
Now you are going to see the Difference in performance.
Oct 26, 2008 | HP Computers & Internet
HP Compaq nc6320 PC Notebook Problem
Try unplugging internal battery for a minute or two it worked for me.
Sep 01, 2008 | HP Compaq nc6320 Notebook
Keyboard problem
First off try a friends keyboard if that works OK then yours has a high probability of being stuffed Buy new one
If friends plays up you have a registry or system fault
Go to windows explorer c:\ right click/properties/tools/check now a box will popup tick the square to automatically fix errorrs reboot when windows reboots it will scan for error and fix them when done will automatically retart check if keyboard is OK
Jul 27, 2008 | Compaq Keyboard
HP Compaq d530 PC Desktop Logo
56 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
