Client has 2008smb with exchange 2007,they have kyocera mfps,the scan to email worked fine with 2000 server with exchange from the kyocera product it has stopped working on the exchange 2007 the mfp uses port 25 we have created a user account and email address on exchange 2007 for the kyocera but the exchange server still wont autheticate it can you help
    President:
  • 623 Answers
Does the printer need/have an account in the domain?
Posted on Dec 11, 2008
Guyscan you help me configure Scan to email from a Kyocera Copystar 250ci printer what settings will i look around to configure scan to gmail or other email clients
You need to find where to enter the settings for an smtp server. (simple mail transport protocol) Most internet service providers allow clients to use their smtp server. For instance, for Shaw in Canada to smtp server is mail.shaw.ca. Some will require authentication in which case you will need to have a valid account with that provider.
Jan 22, 2016 | Kyocera Office Equipment & Supplies
How to recover damaged EDB file from Exchange Server
Affordable and effectively software for retrieving your deleted or damaged server files and convert it into PST format in simple ways.
For more information, you can go on this site :-Exchange Server Recovery
Apr 17, 2014 | Microsoft Office Outlook 2007: Windows
No disk. hard to determine which print driver to use. kyocera cs4035e. networked and scans fine. but no print driver. server is windows 2000. clients are windows XP
You most likely need the universal KPDL driver. There is also a KX driver. Installing both will not effect your system but... again you the KPDL is the most likely driver.
See this download link:
http://www.kyoceramita.eu/index/service/dlc.false.driver.KMC4035E._.EN.html
One if these drivers is going to work for you.
Thanks for choosing FixYa,
Kelly
Jan 14, 2011 | Copystar CS-4035 Copier
Can i use MS Office 2007 on WinXp Home Edition Service Pack 2?
DEAR SIR,
MICROSOFT 2007 WORKS PEACEFULLY ON SERVICE PACK 2,THE ONLY THING IS YOU SHOULD VE ATLEAST 1 GB RAM TO ACCESS IT SMOOTHER AND JUST BEFORE YOU INSTALL M.S 2007,REMOVE THE OLDER VERSION(M.S 2003)FROM UR P.C AND THEN INSTALL IT.......USING M.S 2007 YOU CAN SAVE THE DOCUMENT IN M.S.2003 FORMAT ALSO,AND M.S 2007 HAS VARIOUS OPTIONS WHICH IS HELPFULL TO U THAN M.S 2003...
THANK YOU..TAKE CARE
Oct 12, 2010 | Microsoft Office Professional 2007 Full...
My microsoft outlook will not let me use it it says that my email profile isnt set . how do i set it
here we are providing you gmail client setting so
follow thies steps and configure your outlook
To set up your Outlook 2007 client to work with Gmail:
  1. Open Outlook.
  2. For new setups, select Do not upgrade.
  3. Click Yes.
  4. Enter your display name, email address (including '@gmail.com'), and password. Google Apps users, enter your full email address, e.g. 'username@your_domain.com.'
  5. Select the 'Manually configure server settings or additional server types' checkbox.
  6. Select Internet E-mail.
  7. Settings: name, full email address (including '@gmail.com' or '@your_domain.com')
    • In the Account Type dropdown menu, select IMAP; enter the incoming and outgoing server names shown below.
    • In the 'User Name' field, give your full Gmail address, including '@gmail.com' or '@your_domain.com.'
    • After creating these settings, clicking Next takes you to the end of the setup.
  8. In the Tools menu, select Options then Mail Setup. Under 'Email Accounts,' click E-mail Accounts.
  9. Select an account, and click Change above the list of accounts. Click More Settings, then the Advanced tab.
    • Incoming server must be 993, and must use SSL encryption.
    • Outgoing server can use 587, TLS encryption.
  10. Click the Outgoing Server tab. Make sure that 'My outgoing server (SMTP) requires authentication' is selected. The radio button 'Use same settings as my incoming mail server' should also be selected.
  11. Click OK > Next > Finish > Close > OK.
  12. Check our recommended client settings, and adjust your client's settings as needed.
if(document.getElementById('kb_ie6') != null) showLayer('kb_ie6'); if(document.getElementById('kb_ie6_win') != null) showLayer('kb_ie6_win'); if(document.getElementById('z_ie6') != null) toggleZippy('z_ie6'); if(document.getElementById('z_ie6_win') != null) toggleZippy('z_ie6_win'); if(document.getElementById('kb_ie') != null) showLayer('kb_ie'); if(document.getElementById('kb_ie_win') != null) showLayer('kb_ie_win'); if(document.getElementById('z_ie') != null) toggleZippy('z_ie'); if(document.getElementById('z_ie_win') != null) toggleZippy('z_ie_win'); if(document.getElementById('kb_win')) showLayer('kb_win'); if(document.getElementById('z_win')) toggleZippy('z_win'); if(document.getElementById('kb_winxp')) showLayer('kb_winxp'); if(document.getElementById('z_winxp')) toggleZippy('z_winxp'); if(document.getElementById('kb_IN')) showLayer('kb_IN'); if(document.getElementById('z_IN')) toggleZippy('z_IN'); if(document.getElementById('kb_non_US')) showLayer('kb_non_US'); if(document.getElementById('z_non_US')) toggleZippy('z_non_US');
Nov 29, 2009 | Microsoft Office Outlook 2007: Windows
Exchange Direct Push Only Working when Outlook is open
I have the exact same setup with diffrent BB and now HTC on the ATT 3G network and my HTC are sync when Outlook is open in real time. When Outlook is closed they sync but many hours later??? Real frustrating. Any idea would be great.
Nov 12, 2009 | Microsoft Exchange Server 2003 Standard...
Unable to scan to email after switch to Exchange 2007
check the server settings, maybe user authentication is needed, check from server side, what the printer is trying to do and where it fails. check printer e-mail settings, try these setting in computer.
Oct 05, 2009 | Konica Minolta bizhub C250 All-In-One...
Belkin F5D9230-4 won't allow a connection to M Exchange server
Login to your Belkin router and check to see if there is a firmware update available for your specific model. If so, download and install it as this may resolve the problem without doing anything else. (Be sure to save your configuration first)
The specifications for a F5D9230 state that it supports VPN passthrough so you shouldn't need to configure anything in the router itself. It may be necessary to open a few incoming ports but only as a last resort.
Would you also reply to this post and specify...
  1. What OS are you running on your pc?
  2. What VPN client are you using on your pc?
  3. Ask the administrator of the Exchange server if they're using PPTP or L2TP for VPN connections.
Another option would be to use OWA (Outlook Web Access) to access your email if it has been installed on the Exchange server.
Aug 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Kyocera 3035 under res. i get e023
The KM3035 requires a second network card for network scanning. then use the scanfile utility on the client machine / server to recieve the jobs and dump in a shared folder
Apr 01, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
