Question about Lands Phones
Bought a new Samsung G600 phone. When switched to camera mode, no image appears, only a background colour and settings button. Changing settings does not help. Suspect phone is faulty.
  • 52 Answers
It sounds like a ribbon fault to me common problem on slide and flip samsung phones i do have a camera for a g600 as i have one with a smashed screen and broke it half in temper cause it was doing my head in,the ribbon ya can get on ebay for under a tenner.
Posted on Dec 15, 2008
Why is my samsung xe3o3c12 keep changing colour when i open it
This is just the background. It's set to dynamic or "live wallpaper"
To change follow these steps.
Step 1 Press the "Home" button to return to the main screen.
Step 2 Press the "Menu" button and tap "Wallpaper."
Step 3 Tap "Wallpapers" or "Live Wallpapers" to access the selection of preset wallpapers. Live Wallpapers are simply animated images, such as bubbles, clouds or smoke.
Step 4 Tap a thumbnail and then "Set Wallpaper" to apply it to the Home screen's background.
Nov 21, 2014 | Samsung XE303C12-A01US Chromebook Silver...
How to take pictures of paintings without the image appearing dark using auto focus
It sounds like your camera is under exposing a little. If you can, shoot in "raw" mode, and adjust in the software the camera manufacturer provides. Other things you can do: adjust the white balance for the lighting, override the camera's exposure to get more light, use flash, etc.
Oct 17, 2014 | Cameras
Camera image shows in green tones only. Is there a fix? Thanks.
it could be your camera setting, eg, black white, sepia etc, the colour contrast could have been changed?? if it only does it on camera and not video mode, then its more likely your camera settings, if it does it on video and camera, then it could be the camera its self
May 06, 2009 | Samsung J700 Cellular Phone
Need samsung g600 unlocking code
I have just tried it with my new locked to orange g600 and it works fine on all networks.
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy G600 unlocked
if it doesn't work after step 3.. try changing the 'non-accepted' sim card that ur putting in..
eg if you are locked to vodafone and you try this method and use an orange sim card and it doesn't work, try using a o2 sim or even virgin :)
its easy good luck
Jan 29, 2009 | Samsung SGH-G600 Cellular Phone
I have a samsung g600 phone, new;accepts my sim but no service here is your solution
Jan 18, 2009 | Samsung SGH-G600 Cellular Phone
How to get big ben clock back after changing wallpaper
Settings > Display Settings > Home Screen
Then change the first item marked 'images' to 'Dynamic' with the left/right buttons.
Oct 05, 2008 | Samsung SGH-G600 Cellular Phone
The Samsung software does not work properly with the G600 (take note Samsung) On your phone go to: Settings>phone settings>USB settings>Ask on connection. exit phone and when you plug in your usb it will ask what connection type, choose Mass Storage and it will appear on My Computer as a portable drive, you can drag and drop to folders. You may have to install the USB drivers from the disc or site, but it may work without.
Jan 31, 2008 | Computers & Internet
Lost AutoFocus
Set focus - it is autofocus is it not? Take a few pictures and check whether they are sharp or not Also make sure your finger is away from the sensor window when holding the camera
Aug 07, 2007 | Samsung Digimax S630 Digital Camera
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Lands Phones Logo
106 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
