Question about Ricoh Aficio AP3800C Laser Printer
Paper Jam from the duplex into the Main Unit
Single sided A4 Sheets works fine from all the trays.
Only when Duplexing get paper jam at Point B.
When the paper exits the bottom of the duplex machine, going towards the registration and the idle roller, past the registration sensors.
I have cleaned the registration sensor, the SP5 -803-9 shows up as detected (7) (00000001) (0).
I have replaced the following parts:
1 x AX20-0240 (reg clutch)
2 x AX20-0239 (relay clutch)
2 x AX20-0224 (feed clutch)
Any ideas what else I need to check?
  • 1 more comment
  • Anonymous Dec 11, 2008
    Ricoh Aficio 1232c
  • gremlin11
    gremlin11 May 11, 2010
    what make and model???
    Gremlin11
  • Anonymous Mar 14, 2014
    Main Tray Problem. Main tray is not detected in not detected by main tray top limit detection sensor or main tray capacity detection sensor within 20 sec of ascending. Main tray upper limit detection sensor or main tray load detection sensor is not detected as Off within 20 sec of main tray descending
    Scholar:
  • 78 Answers
Sorry dude, not my thing, great with epson, canon, hp, lexmark, brother but not ricoh
Posted on Dec 11, 2008
FS-4020DN "Paper Jam Deplexer"
check for jamed paper above the paper tray in the duplex unit.
=remove tray
=move green lever and open duplex unit
=remove jam
Jun 27, 2014 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
Duplexing jams
Some of the rollers inside the printer have becomes slick with paper dust on the surfaces of the rollers. There is a printer cleaner paper available at most office supply stores and online. It is sticky on both sides. You run a sheet through the printer a couple of times and it removes the dust from the rollers. In your case, run the paper through the duplex unit too.
Mar 16, 2017 | HP LJ-8000DN Laser Printer
Duplex jam
repalce dupliexer or check the duplexor gears as i ahd it at one point otherwose doa printer ressetr ans ee if problem clears up
Feb 18, 2008 | Lexmark C912 Led Printer
Ricoh Aficio AP3800C Laser Printer Logo
333 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
