Question about Brother HL 1240 Printer
Some features don't function with my USB connection
With my new laptop, I had to change my ancient printer cable and connect to one of the USB ports. But now I cannot print a "watermerk" any more. Some other features (like the thickness of the paper) don't appear any more on my screen, so I can't choose them any more. Is this normal or can I do something about it?
  • 624 Answers
This probably has more to do with the printer driver than your cable. Click on the link below, select drivers and in the box below select the operating system you are using. If you have the right driver let us know what operating system you were using on your old PC and what are you using on your new laptop. Thanks and please don?t forget to rate this posting.
Posted on Mar 05, 2007
  • tomj23 Mar 05, 2007
    http://welcome.solutions.brother.com/BSC...
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
Printer
There is no way- if the computer has NO available USB ports, buy s USB hub ( a multi outlet USB expander/extender cable). If the computer has no USB ports (outlets) AT ALL- it is ancient, but you might be able to install a USB expansion card into the computer and get external ports.
Aug 29, 2012 | Epson Stylus CX6600 All-In-One InkJet...
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
I have a Canon MF6950 Multi function Printer/fax/scanner connected to my network, but not connected locally to a computer. when I try to set up the Scanner, the software is not detecting the scanner. Must...
Yes, the scan to computer feature will only work if the MF6950 is connected to a computer via the USB port. See page 7-2 (page 165 of the PDF) of the Basic Operation Guide for the multi-function MF6950.
The documentation is available here: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-laser-printers-imageclass/imageclass-mf6590?tab=manuals . The direct link to the Basic Operation Guide is http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDMwMDAwMDk1MzAx&cmp=ABR&lang=EN .
I hope this helps. Please note: the scanner requires bi-directional communication with the computer. It may fail if you have a long/damaged USB cable, use a USB hub, or a port problem. If you have an issue on the USB connection, try a new USB cable and a direct connection to the computer before doing any other trouble-shooting.
Jan 21, 2018 | Canon Office Equipment & Supplies
How do I add a printer to my laptop
At this time, a full feature Windows 7 driver solution is not available for your product.Follow these steps to install and configure the driver that is compatible with the product.
Follow these steps to install the compatible driver in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select the Deskjet 660c and then click Next.
  9. In the message window, click Finished .
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK .And print a Test Page.
Regards,
Riztech
Jun 01, 2010 | HP DeskJet 656c InkJet Printer
Connection to laptop
Most printers are connected to laptops via the USB ports. If the printer is supposed to be wireless, then you may have to connect the laptop via the USB port so you can activate the wireless port.
Don
Nov 23, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Chronic message "No Hp Devices Detected"yankedo on Apr 20, 2009" " Have to constantly uninstall and reinstall printer for it to function. Sometimes only lose the scanner function, other times all...
Are you using the ethernet connection or a USB connection? If you are using USB, do you have the printer connected to a hub or directly to the computer? Does changing the cable to a different USB port get the computer to see the printer? If you are using a USB port in a hub, try a direct connection. Does the USB hub have power-transformer or is it powered by the computer? Printers are extremely sensitive to losing data when the cable run is too long or the USB hub has too many devices attached (particularly when powered by the computer). Also try a new USB cable. An additional troubleshooting test: turn off your printer for 30 seconds, unplug both sides of the USB cable and see if it is found when you plug it back in and turn it on.
If you are using an ethernet connection, check the cables for both the printer and the computer. Also try plugging the cables into different ports on your router or switch. I'm assuming you have your network working and have a IP address (if your network gives dynamic addresses). You might try repairing the network connection (right click on the network icon in the system tray in XP or Vista).
If these ideas do not help, I'm not sure what is causing your problem.. I hope this helps.
Sep 19, 2009 | HP Photosmart C5180 All-In-One InkJet...
Computer won't recognize printer
Try each of the USB ports on your computer.
Assuming that you have a USB-cable between the computer and the printer, unplug the USB-cable from the computer, and connect some other USB device (iPod or memory-stick). Does Windows detect that other device? If not, then you need to install the correct software device-drivers for your USB ports.
Is the printer properly detected when connected to some other laptop/desktop computer?
Sep 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
Printer is not working
The Pixma MP210 does not support a wireless connection. It has a USB port. Some wireless routers do have USB ports and can thus share the printer. Similarly, there are print server options that can be connected to the USB port. However, these will not work with the scanner functions of the all-in-one. Also you would need to confirm that the print server you choose is compatible with the Pixma MP210.
The fastest way to print right now is to connect the USB cord to the laptop. Wait for the drivers to be installed and then send the file to the printer. Moving the cable will let both computers use the scanner features of the all-in-one. A manual USB A/B switch might allow you to share the printer with fewer chances for a damaged USB cable. However, these usually don't support the scanner. Scanning requires bi-directional communication between the printer and the computer. A bad USB cable can turn an all-in-one into a single function printer with a direct USB connection.
Once the MP210 driver is on both systems and they are connected to the same network, you may be able to set up the desktop as a print server for the laptop. This will depend on the OS on both systems. Something like the Windows Homegroup easily allows printer sharing when enabled for systems with Windows 7 and newer on a private network. Both systems need to join the same homegroup. One system starts the homegroup. Then you have to type in the password on the second computer. This works even with one system connected to the wireless network and the other connected to a wired port on the router.
On Vista and XP, you could enable printer sharing as well in the Network and Sharing center. See https://www.wikihow.com/Share-a-Printer for the steps With Windows OS versions, the scanner functions will only be available on the computer with the direct USB connection.
I hope this helps. Please add a comment with the OS versions on both the desktop and the laptop if you need more specific advice.
Dec 22, 2017 | Canon PIXMA MP210 InkJet Printer
Brother HL 1240 Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
