Question about Hotpoint Aquarius WF000 Front Load Washer
Hi there my wasing machine do not rinse water out what to do?
  • Hotpoint Master
  • 3,463 Answers
Make sure crease care has not been selected, check outlet pipe and pump for blockage.
Posted on Dec 11, 2008
E17 error code on bosch maxx 6 wasing machine after turning off by mistake during a rinse
Unplug it for ten minutes, consult your users manual, plug it back in. should work ok then.
Nov 26, 2017 | Bosch Washing Machines
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
Jun 27, 2017 | LG WM2077CW Laundry XL Front Load...
My candy wasing machine won't rinse & is holding water
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 06, 2011 | Candy Washing Machines
I just want to know is detergent we use for wasing the utinsils is harmful to our health we should directely use the utinsils without washing it again or not?/
The chemicals are very powerful, but the machine goes through a thorough rinse cycle with rinsing chemicals as well, plus a very hot drying cycle. If you wash the dishes again you are more likely to get harmful stuff on them than if you left them as they come out of the machine.
Feb 28, 2011 | Dishwashers
Hi,I live in korea . AEG,LAVAMAT 72760,When wasing , the washin masine properly operate at the fist. but, the wasing masine stop as soon as Rinse. simutaneously,C3 appear . what is problem and...
Hi- I am retired Englishman living in France!
I would suspect the lint tray/filter- it could be blocked. So many problems are caused by this- machines stop, some show error message, some do not!
I'm sorry but I do not know your particular machine- whether it is front or top loader. For front loaders it is found behind the front lower panel- the filter could be in a similar place for top loaders.
I would check and clean it anyway - and regularly.
Hope this is the cause,
John C
Feb 09, 2011 | AEG Washing Machines
Dirt patches sticking onto washing
You should use a warm water wash for dirty clothes with a warm rinse. Cold water causes more soap scum because it doesn't totally dissolve in cold water.
Mar 05, 2009 | Washing Machines
Toward the end of a wasing cycle there is a tremendous squeaking noise. What might that be? I thougth maybe the pump but then when it was draining the soapy water it would happen too. I noticed it last...
If it only happens when it is draining then there is a problem with the pump, could be something fast in it, remove pump and check., or if it is there all the time then it is to do with the motor or the drum..
Remove belt and see if the noise is still there, if it is then it is your motor'
Plz rate this solution.
Dec 11, 2008 | Washing Machines
All setting are only washing via 1 cycle
be sure both faucets are full on and hooked correctly most washers have only cold rinses
Nov 29, 2008 | Kenmore Washing Machines
Samsung fuzzy wasing machine WA75N6
sad to say, he is correct. when all indicaters come on together and do not extinguish, the board needs to be replaced
Aug 07, 2007 | Whirlpool LSB6200KQ Top Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
35 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
