Question about Hotpoint Aquarius WF000 Front Load Washer
Hi there please my problem
My wahing machin model WF240 aqarius donot rines it meanes not throing water out.please tell me
  • Hotpoint Master
  • 3,463 Answers
Make sure the rinse hold button has not been selected, deselect if it is, possible pump blockage
There is a filter located in the sump hose at the rear of the m/c.
Remove lower rear panel and undo large hose onto drum , filter inside there, remove and clean if neccessary.
Make sure nothing is stuck inside pump, try a drain only prog and you should be able tohear and see if oump is working BE CAREFUL.
Posted on Dec 11, 2008
Washing machine help
1. The water pressure could be to low. 2. The waste pipe could be too low.
on the back of the machine you can see 2 red arrows that is the minimum height of the waste pipe.
Mar 04, 2012 | Washing Machines
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Mar 15, 2011 | LG Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
We've scrubbed off the wash info on the front of the machine!
In your main browser bar, type in-----------HOTPOINT.CO.UK
In the drop down menu, click on----------After sales.
Enter the model number of your washer in the box, and download the instructions.
Please rate my solution.
Thanks.
Nov 10, 2009 | Hotpoint WF430 Front Load Washer
I have an initial fill problem with a Hotpoint Aquarius Washing M
You can attempt to reset the water level, but it sounds like that system is malfunctioning and going to require service.
Oct 29, 2009 | Washing Machines
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
I have had aqarius a hotpoint aqarius 1000 wm62p
It has a wide variety of wash programmes for white cotton, colourfast cotton, polyester, non-colourfast cotton, wool blends and wool itself. These standard programmes take from an hour and a quarter to three-quarters of an hour to complete.
There is also a quick wash programme lasting just under half an hour for lightly soiled items and a pre wash soak for heavily soiled items. The machine has four buttons providing extra facilities that can be set independently of the main wash programmes to give you a more comprehensive range of settings.
There is a rinse hold button, which I find extremely useful. When set this holds the clothes in the final rinse water until you are ready to unload the machine. You then release the button, let the machine go through the final spin and then you can unload the machine. It means that you don’t leave damp washing in the machine for the time between the cycle finishing and you unloading the machine, which would make for very creased clothes. There is also a button to depress if you want to use the super rinse facility. This merely increases the volume of water in each rinse so that the clothes are rinsed more fully. I have never used this particular facility, as the ordinary rinses are fine for my needs.
The next button allows for a slow spin. I find that this one is really useful for the items that I need to iron as it means that they don’t come out of the washing machine as creased as they normally would on a faster spin. The only problem with this is of course that the clothes are not as dry as they would otherwise have been. The final button is used to set the economy wash feature. This means that the washing machine’s own heating system is not used and the wash is done with the water at the temperature entering the machine from your hot and cold water tanks. This of course means a cooler wash so it’s only suitable for lightly soiled items.
The door remains locked during the wash programmes so that it cannot be opened accidentally and it can be locked when not in use too if you have small children who might get into mischief! The other big selling point for this particular model is that it gauges the size of the load and uses the correct amount of water needed eliminating the need for the half-wash programme. This also means that it is both water and energy efficient
Mar 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WAHING MACHINE ACTING UP
E31 ERROR MEANS. Pressure sensor not communicating with control board.
PLEASE CHECKOUT THE PRESSURE SENSOR.
Nov 09, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error message - "check Rec. Paper"
Check rec. paper means that the paper may not be routed properly thro' the cutter mechanism and out thro' the machine....if it is; then the sensors that detect the paper may be dirty or faulty.
Mar 31, 2008 | Muratec M1250 Fax
Hotpoint Aquarius WF000 Front Load Washer Logo
113 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
