This allows you to adjust the temperature to match what you are drying. Some fabrics and clothes require low heat or you may only be drying a small amount of clothes and don't need much heat. You also may not want high heat to avoid shrinkage of some clothes.
Unfortunately, it does not look like there is a replacement part available for your Farberware Toaster Oven model #510615. You may want to consider purchasing a new toaster oven.
Your stitch selector knob is still set on the 3rd leg of the buttonhole. Turn your knob left further and it should go down to a straight stitch or zigzag.
If it doesn't, put a drop of machine oil in all the places that your instruction book tells you to, and after running it for a minute or so, try it again. It should eventually release and start sewing forward. If it doesn't, you will need to see a mechanic.
Good Luck
H:H 80 on a Miele microwave indicates that the microwave's Keep Warm feature is in use. To end the cycle, open the microwave door or operate a selector or sensor (press a button (not the time display) or turn the selector knob). The keep warm setting runs the microwave for 15 minutes at 80W power starting 2 minutes after any program that used more the 450W of power. You can turn off the Keep Warm feature completely in the microwave settings. To change the setting, touch the menu button (arrow and three horizontal lines). Press OK and turn the selector knob until you see P9. Press OK and then turn the selector knob to change the setting. Press OK to save.
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Have you installed the stitch selector pattern module for the patterns you want, seated it properly as outlined on page 52 of the instruction book following all 7 steps? (Page 54 identifies the knobs and lever's that need to be moved to successfully install the pattern module)
If that is done correctly, then selecting a stitch is done with the stitch selector lever being moved under the letter corresponding to the stitch you are trying to select. (Shown beginning page 55) You also need to move the stitch length knob as indicated.
You will need to be sure you are following the instructions very carefully as there are a number of settings that need to be made to ensure you get the stitch you are trying to achieve.
C: Disables clean mode in Thermador device, allows cook and microwave
E: 1. Turn the clock selector knob to OFF
2. "Tweak" the oven control by turning the clock selector knob slightly to the left
(counter clockwise).
This may stop the flashing message/beeping and clear the display window.
When selecting "Hot Water," can you hear a pump working (usually a strong buzzing sound)? If you do, then water path may be blocked or pump itself is jammed. A jammed water pump still makes buzzing sound. May be stuck from not using, for long period of time. Especially, in hard water areas.
You have to buy descaling tablets from miele. You turn the knob to program mode and keep pushing the enter button until you get to descaling. You put two descaling tablets into your water reservoir and replace into unit. Put containers under the steam valve and the hot water wand. Press enter. Turn steam valve al the way on. Keep an eye on the containers. The process takes about 30 to 40 minutes. The message will appear 'Descaling finished." Turn steam selector to O and press enter. Display will read "rinse machine, fill watertank. Fill tank and return to machine. Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely. When process is finished, display will read "Rinsing Finished." Turn steam selector to O and press enter Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use. Turn program selector to on.
