Question about Toshiba Satellite 1135-S125 Notebook
Toshiba Satellite 1135-S125 front LED indicators gone weird
Hi, Recently, my Toshiba laptop was plugged in to AC power, without the battery installed, when we had a brief power outage. When my daughter turned the computer back on, the on-off and battery LED indicators (which were green) turned amber. The battery indicator was lit, even though the battery was not installed. And the CD-ROM indicator light remains lit all the time, even when there is no disc in the drive. Did something get fried when the power outage happened? Is there some setting I can change that can return the LEDs to normal? Or is there a board that needs to be replaced? It's not a critical problem - the laptop still works fine and the strange operation of the LEDs doesn't seem to interfere with anything. Any help would be greatly appreciated. Thanks.
  • Dan Dennis Mar 06, 2007
    Thanks for the information - I will try that solution. And your English is better than most native English-speakers I know. :-)
  • Dan Dennis Mar 08, 2007
    I tried both suggestions, but neither one seemed to work. Everything else seems to work fine, and I'm tempted to simply ignore the issue. But I'm still worried that it's one symptom of a larger problem. But bogdan and adi_techmax, both your suggestions were well thought-out and I had not considered them, so at least I learned some things.
  • 57 Answers
As you said that the Green light turned Amber, and the battery indicator was on, i would recommend that you Power Flea your laptop i.e. do nopt connect the battery/adapter to your laptop and keep on pressing the Power switch for almost 10-25 secs. This is because of some static charge built up. Try it and lemme know...
Posted on Mar 07, 2007
    Novelist:
  • 198 Answers
Hi The strange operation of those LED's is most probably an error mode indicator. If a laptop fails to power on corectly it will use those LED's, lighting in a specific pattern to signal the error. That's an example. In your case something was damaged in some way because the error code indicator is still acting like there is an error. You may try to reset the BIOS to factory defaults (small chances that this will work) and leave the laptop unpowered for about 1 day. If the problem is still there you will need to have it fixed in a service center. By comparing the LED lighting pattern with information from the Toshiba service catalogs they will be able to tell you what kind of error had happen for wich the LED's to light in this manner. Sorry for my bad english, I live in a non-english speaking country. Good luck and don't forget to rate any answer received from this site.
Posted on Mar 05, 2007
SOURCE:
Need driver : PCI modem, video controller for a toshiba satellite 1135 s125
here is the link for all the device drivers on the webpage.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=430235&rpn=PS113U&modelFilter=1135-S125&selCategory=2756709&selFamily=1073768663
go there and modem/display drivers are on the 1st or 2nd page.
click on the link and download and install for your laptop.
Aug 07, 2011 | Toshiba Satellite 1135-S125 Notebook
Toshiba A135-S4527 laptop ** Battery not charging!
Check the power input jack soldered connections for cracks, resolder them as necessary.
May 15, 2009 | Toshiba Satellite 1135-S125 Notebook
Wont Reinstall Software
They Only thing that could do that During Format is a Bad Harddrive.
Feb 04, 2009 | Toshiba Satellite 1135-S125 Notebook
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Removing the hdd in my toshiba 1135-s125
OK, This is a big undertaking if you are completely new.
1st, if you can get a static guard wrist band - great!
2nd You will be dealing with plenty of screws so keep track
In Toshiba notebooks most screws are marked. Here are some examples:
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
I have .a Toshiba Satellite 1135-S155. It should be a similar configuration, same family/1135-S1xx series.
You will have to remove a total of 9 Phillips screws.
Place the underside of the PC up.
Disconnect all power, cables and Battery from Laptop
The first screw is located just under the Toshiba Serial Number / Bar codes, just above where the DVD/CD-ROM combo drive is located.
Mine is labeled (F5). Unscrew it and place in a safe place.
Pull DVD/CD-ROM combo drive out it is an assembly.
The Hard Drive is located under the DVD/CD-ROM combo drive.
The Hard Disk Drive (HDD) is enclosed within a caddy containing the remaining eight screws.
There are four screws holding the caddy rails to the Laptop and four screws holding the rails, caddy and Hard Drive as an assembly.
Unscrew and place in a safe place/ container they are small. Disassemble the HDD from caddy assembly; place your HD in the caddy and reassembly.
Here is another Toshiba HDD access that is slightly more
straightforward than my 1135 series
So you get an idea of where a HDD is visually:
Above is a photo of the Battery sliding out
Below is the Hard Drive Removal
I hope this gives you an idea of how to go about it for your
particular Laptop
If you need further assistance, let me know
Feb 21, 2008 | Toshiba Satellite 1135-S125 Notebook
Satellite 1135-S125 dvd upgrade
Could you post a picture if the drive and show front and rear of it? Most are standard drives but some toshibas are different.
Jan 05, 2008 | Toshiba Satellite 1135-S125 Notebook
Toshiba satellite 1135
There should be some loose connection or a broken power cord. You may have warranty for the laptop and accessories, replace immediately
Oct 27, 2007 | Toshiba Satellite 1135-S125 Notebook
Toshiba Satellite 1135-S125 Notebook Logo
432 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
