Question about Dell Latitude D600 Notebook
Bluetooth does my laptop have a bluetooth device? and if so, how do i activate it.
    Scholar:
  • 149 Answers
It would seem that your laptop does not have inherent bluetooth capabilities....you can however buy a usb bluetooth adapter which are relatively cheap
Posted on Dec 11, 2008
    President:
  • 1,073 Answers
Nop, it says in the spec that your laptop has IR but no bluetooth
Here are the spec for your laptop
http://www.itema-pg.com/PC/Notebooks/dell/d600_spec.pdf
Good luck
How activate bluetooth
Plug a Bluetooth adapter into a USB port on your computer.
If a Bluetooth adapter is already built in to your computer, ignore this step.
Flip the switch or push the power button on the Bluetooth device to turn it on and make it discoverable.
Click the "Start" button on your computer and select "Control Panel."
Click "hardware and Sound" and choose "Bluetooth Devices."
Click "Add." Follow the onscreen instructions, which vary depending on the kind of device you are installing.
The instructions mostly consist of clicking "Next" or verifying that you want to install the device.
You now have activated a Bluetooth device on a Dell laptop.
hope this helps
Aug 30, 2012 | Dell Computers & Internet
I have Dell Inspiron 1525 Special edition, Please suggest How I should activate bluetooth ?
To active the bluetooth please follow the instructions below;
  • Go to start
  • click the control panel
  • select hardware and sound
  • click on the bluetooth device option
  • click on the bluetooth options at the top then click activate
please note:
If you do not have "Bluetooth Devices" listed, this means that your Inspiron does not have a built-in Bluetooth chip. Therefore, you cannot activate Bluetooth on your pc without a third-party Bluetooth adapter and software.
Jul 15, 2011 | Dell Inspiron 1525 Laptop
I m not able to connect to bluetooth and wifi please help!!!!!!!!!!
Your dell bluetooth must be turned on before able to pairing with other compatible device. Please check bluetooth switch on your laptop keyboard ( if there is you must turn it on also). Most of bluetooth devices are compatible.So please try again your bluetooth pairing .
To activate the wifi , you must covered at active wifi area / Wlan ( hotspot), then click your internet connection on right below corner ( beside battery sign) and open network and sharing center,then activate your wifi . This wifi will not work if you are outside wifi covered area.
Regards
May 14, 2011 | Dell Vostro 1014 Laptop Computer
My bluetooth device dose not active please help me how can I active my latititud E5510n's bluethooth device. thank you very much. saeid
Hi
I think the bluetooth key ( if you have bluetooth installed ) could be the FN+F11 key or which ever is the wireless switch on your laptop i believe that both wifi and bluetooth shares the same key
Feb 26, 2011 | Dell Latitude E5510 Notebook PC
How to activate bluetooth? (driver is installed)
Press the Bluetooth button on the Laptop and it should enable the bluetooth function.
If that does not help, try the steps below.
Click on Start Button, Control Panel, System. Next check to see if your have a "Bluetooth device in your list (should be at the top under Bluetooth Radio's)
If you computer has the device installed it will tell you. If you right click on the device and go in under properties it will tell you if the device is working properly. You may need to just update the driver
Basic steps to check bluetooth connectivity or activity is.
1. first enable/start bluetooth on ur Laptop & Mobile !
2. then search for devices in the menu..
3. it will show u a list or a name of ur single device..dat may be ur laptop/mobile name !
4. select dat device and it will make the connection
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | Aspire Acer AS5315-2856 Laptop
Don't know how to activate bluetooth device that is built in the laptop
Hello, thanks for using fixya.
dependig on the laptops, they usually use a specific button or is the same as the wireless , and you need to check if the drivers are correct installed .
i hope this help, any thing just let me know.
Thanks
Nov 23, 2010 | Computers & Internet
Activating bluetooth
hi.
lahansseynar,
first you have to download the driver of the bluetooth device from the dell driver &utilities cd & then u can recive and send diffrent items to another bluetooth device.
Dec 21, 2008 | Dell Vostro 1700 Notebook
Bluetooth and IRda in Acer aspire 5320
Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1 , click Control Panel, click Printers, and then click Bluetooth Devices. Nearby devices are listed on the Devices tab. First, you must have another Bluetooth device near you, it will not activate alone.
Dec 20, 2008 | Computers & Internet
Bluetooth Problem
this will help
go to device maneger
check for your bluetooth device
check if it is activated
if not activate it
you could also check for driver details
just incase you dont know how to go to device maneger
if your using MSwindows any ver. go to system properties
Jan 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell Latitude D600 Notebook Logo
151 people viewed this question
Alun Cox
