Question about Canopus ADVC-55 Video Capture
Black and white and no sound in Final Cut Pro
I'm playing NTSC VHS tapes on a VCR that plays both NTSC and PAL tapes - but regardless of which setting I use (NTSC or PAL on the ADVC-55), I get no sound. With NTSC settings I get an image but it's in black and white. In PAL settings I get colour of the VCR's blue screen, but no images when it starts to play. I have nearly a hundred VHS tapes to convert. Please help!
  • 1 more comment
  • Anonymous Jan 07, 2009
    I have similar problem in imovie. I am getting sound and images but only in black and white.
  • holliscamero Feb 10, 2009
    Did you find a solution to this?
    I have an ADVC-55 hooked up to an old sony Hi8 and im trying to capture to quicktime7.5.5pro or fcp 5.14 and both give video but no audio. Im thinking maybe a simple head cleaning? the other thing i think it might be is that my audio sample rate is 48kHz and im willing to bet this camera is 16 or 32. but i dont have a DV NTSC 16 or 32 capture option.
    bummed and confused, please help.
  • Anonymous May 08, 2009
    MAC/Black and white in Final Cut problem ? !(
5 Suggested Answers
SOURCE: IMac and ADVC 110 via firewire = Nothing
this just happened to me tonight...whats going on?? is this some recent leopard related error?
Posted on Jan 11, 2008
  • 119 Answers
SOURCE: vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Posted on Apr 05, 2008
  • 119 Answers
SOURCE: ADVC-110 not working for me
iMovie or Final Cut Pro should work.
  • 23 Answers
SOURCE: "no device control" blue screen on imovie with ADVC55 connected
Hi - The red light indicates the VHS is Macrovision copy protected, so the ADVC55 is refusing to import it.
There is a sort of "secret" workaround for this that most people who own the old Canopus products know, and which Canopus also knew, supported, and had posted on their forums (unfortunately deleted by the new owner who seems to be unclear on copyright law).
Remember, it is LEGAL to make ONE (but ONLY one) copy of any copyrighted material for your personal use for backup purposes. In other words, if you do this, you can record the movie into your computer and store it there, or burn it to a DVD (after which you must erase the copy on your computer), but that's all! You cannot make another copy for anyone else - not even yourself - without violating copyright law.
That said, here are the two procedures that usually work, easiest first:
1) When you first turn the Canopus on, hold the select button down for roughly twenty seconds. Now the system should ignore any copy protection until you turn the unit off.
2) (if 1 doesn't work:)
1. Put all dip switches OFF (unless you have a PAL system). 2. Hook up the firewire cable from the unit to the PC while ensuring that both units are OFF (this is what the instructions say to do, because you can cause a damaging power surge otherwise).
3. Turn on the power to the DVD player, PC and ADVC-100.
4. Set capture on your PC (your software) to Manual.
5. Start the DVD.
6. The ANALOG IN LCD of the unit will light, and if the DVD is Macrovision protected, the red STATUS light will stay on for about 18 seconds, turn off for about three seconds, and then repeat the process (or may remain red longer on some units).
7. Depress and HOLD the INPUT SELECT silver button. The DIGITAL IN LCD will light up temporarily then turn off. Keep this button depressed until the red STATUS light stays off completely (about 15 seconds).
8. Release the INPUT SELECT BUTTON and press it briefly one more time until the ANALOG IN button lights up.
9. Macrovision is now bypassed!
Again, once you turn the ADVC55 off (which you must - if it stays on for long periods it can overheat and malfunction), you'll have to go through the Macrovision bypass procedure again next time you turn it on.
Good luck, and I hope this works for you as it did for me with my Canopus!
Posted on Aug 05, 2009
I want to play an NTSC tape on a PAL television
This is a VCR alone machine?Not a DVD and VCR combo?VCR alone machine dosen't have auto NTSC/PAL setting to play all the world regions.
May 28, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Trouble recording and playing NTSC tapes on NTSC TV!!
Sounds like the video head is dirty. Take the top cover off VCR, locate the video head, which is the rotating shiny aluminum cylindrical piece. At the lower edge of this drum are the actual heads. Use a lint free cloth moistened with rubbing alcohol or product specifically designed for such cleaning, and carefully wipe the heads and drum. Just hold cloth over a finger, and rotate the drum. Sometimes you will need to do this a couple of times.
If VCR has alot of hours or an abrasive cleaning tape has been used excessively, the head could be worn out and a candidate for the trash, unless it is a high dollar unit.
Jun 11, 2008 | Aiwa HV-MX100 VHS VCR
VHS code compatibility
The video standard in Japan is PAL while it is NTSC here in the USA. You should be able to locate a VCR than can play both. If you'd rather not purchase a new VCR, some locations that create DVDs from VHS tapes can usually also read PAL tapes.
Mar 18, 2008 | Televison & Video
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Aiwa mx100 (al system vcr)
if your vcr is a multisystem, select the proper system in your vcr for the video to be played. but if not, you cannot play your PAL in your NTSC vcr. good luck!
Feb 25, 2007 | Aiwa HV-MX100 VHS VCR
Our Aiwa MX100 doesn't play our pal system tapes
Just Clean the Video heads with a Wet Type Head Cleaner. Do 2 or 3 runs. Should clear up the problem.
Canopus ADVC-55 Video Capture Logo
208 people viewed this question
Top Canopus Televison & Video Experts
Alun Cox
Troy Staley
Troy Staley
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
