Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
Zanussi zx99 fridge fault - freeze working fine, but fridge hs stopped keeping thing cool. If we switch off and leave for 24 hours - works fine. I heard something about a pipe that allows recirc. air into the fridge can get frozen and have this impact - what do you think and how can we fix long term??
  • 67 Answers
The problem is very common full out the plastic cover inside the fridge, check the heater glass heater or allominume heater check the continuity of the said heater if ok, check the thermal fuse conecting the wire of the heater, very small thermal fuse have plastic cover, good luck god bless boss_frnd@yahoo.com
Posted on Dec 13, 2008
  • 26 Answers
Cool air from the freezer evaporator bettery is blown up into the fridge from two air ducts. If the evaporator becomes ice bound the ducts get blocked. The common fault on this appliance is the evaporator sensor failing thereby reducing the defrost period. Have a look through the grill on the evap.cover. If there is excessive ice then that is your problem.
It has been known for the defrost heater to go open circuit causing similar problems.
I would advise you get a Zanussi engineer to attend this appliance as repairing this unit is not really a DIY job.
    Novelist:
  • 161 Answers
You have a defrost system problem. When you turn it off the ice melts on the cooling coils so, when you turn it back on it works.
The defrost system consists of a timer, heater, and thermo disk. Any one or all could be bad. If you want to DIY I can give you more details: ronbuice.com
Posted on Dec 12, 2008
Hi, I have a Zanussi ZBB28440SA integrated fridge freezer, the fridge section is no longer cooling yet the freezer seems fine? Any help would be great!
unsure as to what problem might be , but refrigerators at 16 degrees would be freezing things solid here in the US if you are suggesting the temp is in centigrade them perhaps the damper motor controller has failed on it and you need to seek professional help to replace it
Dec 31, 2017 | Zanussi Refrigerators
Fridge works for about 3 weeks then freezer freezes up and fridge stops working i unplug it for 24 hours and it works for another 3 weeks same story??? what do i dooo? it is a ge side by side newer...
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts check if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Apr 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
I have zanussi zx99/5w and fridge not working and freezer cold but not freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 17, 2010 | Zanussi ZX99 / 5 Bottom Freezer...
I have a zanussi electrolux zx99/5w the freezer is working but the fridge isn't cooling down
LOOK INTO THE FREEZER SIDE AND IF THE BACK OF FREEZER HAS ICE OR FROST BUILD UP / THE PROBLEM IS A DEFROST PROBLEM . The ice build up is blocking the air flow through the cold coil . the correction would be to repl the heater of the a d c control whitch controls defrost .. hope this helps ,mm
Jul 22, 2010 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi Zx99/5SI fridge not chilling freezer Frozen over
Tell you what, first do a good 12 hour defrost and restart. Chances are you left the door ajar accidentally. (even though you say you never,) Most of the time there is the issue. If it continues after that, let me know and ill go through the defrost procedure (the cheap way)..
Sep 26, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Freezer not freezing
Check your temperature setting.
Feb 04, 2008 | Electrolux ER7926B Bottom Freezer...
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi ZX99/5SI
you have a fault in the defrost system - possibly due to a faulty module
Jul 14, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
588 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
