Question about AEG Lavamat 16810 Front Load Washer/Dryer
Fitting door handle to aeg lavamat washing machine
I unscrewed the front of the door to fit the new door handle. A 4cm long spring fell out, and I have no idea where that comes from. Plus I now can't remember which way round the catch fits, or how the spring mechanism should work. Help!
  • superdave156 Dec 31, 2008
    The handle broke and I had to open the door with a piece of strimmer line inserted behind the door and pulled hard top and bottom. The door popped open. I removed the visible screws but the door won't come apart. The plastic of the door has got a bit damaged now.
5 Suggested Answers
SOURCE: door seal is burst
http://www.espares.co.uk/product.aspx?id=547927&source=sc&WT.mc_id=sc00001
Posted on Nov 11, 2007
Timon90
  • 126 Answers
SOURCE: How to re-fit front rubber seal on Lavamat
The seal is mounted to the outertub with a big spring, an on the frint with a plastic ring. Not very easy.
Posted on Jan 24, 2008
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
  • 489 Answers
SOURCE: lg wm1280fhd Spring loaded door catch
Dee,
This one is hard because I don't have any information about your model #.  Are you sure the model # is correct??
Posted on Apr 28, 2008
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
Door wont lock befor i start washing mashine after i fixd handel wa cud be rong
door locks can be tricky did you replace the complete door assembly with new ?
and did you brake the door handle that is why you fitted a new one ?
have you also replaced the inner door lock?
let me know
Dec 10, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
How do you fit a door seal to a AEG LAVAMAT 66600
Thank you for contacting fixya.com.
Please check this video along with the tutorial to install the door seal in your washing machine:-
http://www.apart4u.co.uk/video-tutorials/washing-machine-repair-videos/how-to-fit-door-seals-gaskets/aeg-how-to-change-or-fit-a-washing-machine-door-seal-or-gasket.html
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | AEG Washing Machines
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Nov 12, 2009 | Washing Machines
Repacing the door seal on my oko lavamat washing machine
this could be out of the door tension clip you might see it in this video
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Sep 04, 2009 | AEG Lavamat 88840 Front Load Washer
I have an AEG Lavamat 16820 washer dryer and the door wont open any ideas
The lock is rubbish on this machine but as a temporary measure you can feed a string down behind the door lock from the top and out the bottom. Then yank it to the left to open the lock. It will take a few tries but you get the hang of it!
We got sick of this so ordered a new lock off the net. I basically had to break the old mechanism to fit the new one because the door layers were so strongly glued together. Now fitted, the lock works perfectly but the machine thinks the door's open the whole time! Next step is either new door or new machine. Great.
May 04, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Jan 20, 2008 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat w1450 electronic.
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Nov 12, 2007 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
840 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
