Question about RCA Televison & Video
My tv will not turn on any more.
I have a 52 inch Rca tv that was working fine and then started to act up by not coming on right away and would have to turn off and back on and then it would work. It did this for about a week and then it would not come on at all and it makes a funny sound when it is pluged in that almost sounds like a bad hard drive would sound thats the only way I can discribe the sound. I am not sure of the problem but am wondering if it is the power supply or thr flyback or if it might be something else. Was told by repair shop it might be power supply and was going to have him repair it but he closed up and now the nearest is to far and I now I could do it if I new which part to get and where to get it.
  • 2 more comments
  • freebird9000 Dec 15, 2008
    P46921 is the model #
  • freebird9000 Dec 20, 2008
    Chassis # PKT195M26A and the year is March 2002
  • ladywinn
    ladywinn May 11, 2010
    Need Year of tv and chassis number .,Your model number means set is a 46 inch not 52.
  • ladywinn
    Whats the model number for set HD52W20 etc.....or ????
  • RCA Master
  • 5,138 Answers
OK,These sets are well known for Bad Flyback transfomer and shorted hori output transistor,noise your hear is caused when hori output is shorted .FBT# 239111 Acme has them with 1yr. warranty have phone number at shop will get back to you with that asap.replace these 2 parts and that will fix TV
Posted on Dec 20, 2008
We have a 52 inch RCA projection HDTV and today it just stopped working. It doesn't turn on at all. There is no power light or sounds or anything coming out of it. It was fine the night before and when I...
I had the same problem which got fixed today. It was a loose connection to the power supply unit that required some soldering by a technician and cost me 56$. My TV works after 2 months.
Aug 28, 2010 | RCA D52W23 52" HDTV CRT TV
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Light
My RCA 52 inch was doing the same thing.  TV guy had me use a regular hair blower blowing very hot on the power supply board ( bottom left in back). After a few minutes the tv would come on.  He replaced 2 capacitors, charged me $100.00, plus the $95.00 service call, and is working fine now.  This was a month ago.  So far so good.  He only took the board to the shop, not the entire tv.  Hope this helps.
Oct 04, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
