Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dishwasher drain solenoid
My ge nautilus portable dishwasher quit working. When I turned it on, the dial would not move through the cycles at all and the dishwasher just ran constantly untill I noticed the smell of burning plastic and shut it off. I didn't know it was the timer at first, and instead I replaced the melted drain solenoid. I had some trouble installing it and think I may have done it wrong. I plugged in the wires to it, and turned on the washer, but it still didn't change cycles.Again thinking it was the drain solenoid, I checked the wires again and realized I plugged it in backwards. After that, I tried it again and when the dial didn't turn, I turned it myself. It worked that way, so I ordered a timer and installed it.Now the cycles change as they should, but the dishes are still dirty and the soap it still all over them. The water doesn't come into the dishwasher with enough pressure to move the sprayer arms correctly.I think it is the solenoid. See, the water is draining slowly into the sink during the wash cycle. I don't think it should. I checked the solenoid again, and it is stuck halfway between open and closed.Frozen there. I don't understand what I did wrong for sure. I know I need another solenoid, but I want to know what I did wrong first so I don't repeat the mistake. Can't find a diagram of a properly installed drain slenoid, which would help alot.
  • melissa abbate Mar 05, 2007
    Thanks Catriver. That makes sense.I will order another solenoid and let you know what happens. I'm glad I didn't fry it by installing it wrong.
    President:
  • 878 Answers
Snoopy, first of all you did a good thing when you ordered the timer. I have got stung on this model by just changing the solenoid. The fact is the timer is stalling and sending too much voltage to the solenoid and burning it up. Just order the new solenoid and install it. The solenoid is a AC circuit so it doesn't matter which way the harness is on, you should be just fine with the new timer..Catriver..post back.
Posted on Mar 05, 2007
SOURCE:
My GE Nautilus portable dishwasher will take water in, the motor will hum for a few minutes and then drain out into the sink. This process repeats but the water never cycles inside to actually wash the...
Try manually adding water to the dishwasher. If it works then the water valve is just clogged. Sometimes it gets full of gunk and the machine will take in water but not enough to run properly. It is in the upside down cup shaped thing on the bottom left front. The other possibility is the Cam/Timer. It is in the door right behind the dial. This is the part that triggers all the different actions.
If when you add water it doesn't work then the valve or the solenoid on the pump assembly is likely done.
Feb 24, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus dishwasher isn't draining... PLEASE HELP
Check floater valve.
Inside the unit. On the floor. Looks like and small upside down cup.
If it is jammed in the up position it will stop the machine. Lift, clean underneath. It should drop and the machine will run.
The float valve stops the machine from over filling.
Could also be clog in the drain filter. Remove the cover from the drain inside the unit. look for clog in the filer of the drain.
If none of the above it is the timer. The timer tells the unit what to do (fill, run, empty). If it is not working the drain function will not run.
Adrian
Mar 07, 2010 | GE Nautilus 24" Built-in Dishwasher
Soap dispenser does not close
Make sure the dial is at the start positon and not in between on some other setting.
Sep 04, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
The door for the soap dispenser is stuck half open even after I ran it thru a couple of cycles
This may or may not be the answer you are looking for but I know with mine the soap dispenser will not close unless the outside dial is completely in the "off" position. Trying turning the dial clockwise very slightly. If you hear a click and it resets the soap dispenser position that should work. Otherwise I have no idea. :)
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Water does not drain from GE dishwasher.
Remove the drain hose from under the sink to verify that there is no clog. If the dishwasher runs in the "cleaning" cycle, but won't drain, you either have a clog or a bad solenoid. All the solenoid does is opens a little door to change from cleaning cycle to drain cycle. This part is VERY EASY to change. Definitely a project for DIY. The part runs around $60 from a parts place. Check ebay if you do not need it immediately and you can save abt $30.
Aug 16, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
My GE Nautilus dishwasher keeps PUMPING water "out" of the machine during the entire wash cycle. I have removed all covers in the bottom of the unit to see if anything is stock. Used vinegar and CLR to...
If this convert-able dishwasher is permanently installed, you will have to take off the lower access panel to get to the pump area. If it is still in a portable configuration, it may be easier to lay the dishwasher on it's back or side to do this. Now, examine the pump / motor assembly. There is not a separate water pump on this model. There is a diverter pump out solenoid which get's pulled down to direct the water out the drain hose for pump out, which is suppose to spring back out of the way to allow water to go up to the spray arms for washing. I suspect that the solenoid got to hot and the plunger will no longer slide in the solenoid. If this is the case, you can replace it with a WD21X802. If the arm and plunger move freely, check the spring, or for obstructions in the pump housing, or possibly the diverter arm in the pump housing has come loose from the shaft. The solenoid is the most likely.
Apr 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not drain (water just trickes out) fill is good
Drain valve not opening or pump impeller loose on shaft - is it washing ok?
My guess would be drain valve not opening. It is a 110v solenoid and they get stuck or burn up. New solenoid costs ~$20.00
Mar 26, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
436 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
