Question about Dell Latitude D600 Notebook
On AC Power
My problem lies on the power side of things...When I connect the AC adapter/charger to the laptop, It has to be jiggled and moved around to enable the "On AC Power" indicator. (Pic of AC in taskbar) Is there any way to test whether the problem is coming from the AC adaptor or the DC on the motherboard...without going out and spending $100 for a new cord? I could really use any advise or direction...
Thanks in advance... My notebook power light comes up and imediately goes off whenever i press the power button. Nothing comes on the screen.
  • Anonymous Apr 23, 2009
    same
    Scholar:
  • 149 Answers
You can get the adapter tested by an electrician or someone with a multi meter....that would be the first step....if the problem resides with the DC in then you'll need a professional to sort that out....what often happens with adapters though is that they don't produce enough ampage for the P.C....might be worth checking Dell support to see if they've produced an adapter for your model with a slightly higher ampage ...
Posted on Dec 11, 2008
  • 53 Answers
It does sound like a power cord problem. You can test it by getting a digital mulimeter and checking to see if there is 19.5 Volts DC power on the contact points of the barrel plug that goes into the laptop.
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: On AC Power
Here is a tutorial on how to resolder the DC jack:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
You would need to take your laptop apart down to the system board. Here is Dell's site with the service manual:
http://support.dell.com/support/edocs/systems/latc400/en/sm/index.htm
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 01, 2008
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Mar 15, 2013 | HP Pavilion Computers & Internet
Toshiba satellite won't go on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 01, 2012 | Toshiba Satellite L355-S7811 Notebook
My laptop is not charging. i plug the power in but still doenst charge. im not sure if its on the power cords or on the laptop please help asap i need my laptop for school :(
Does the laptop work on AC ? Is the battery or cord/charged a replacement? First, try another cord/charger of the EXACT same specs as original. Second, Is the battery good? How old? Over 4 years? Have it tested. Beware of inexpensive aftermarket batteries and cord/chargers. I assume the laptop works on AC? If you unplug the AC , with battery in, the laptop shuts down immediately?
Nov 26, 2012 | Lenovo IdeaPad Y450 Notebook
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
I have an Acer Aspire One and when I plug the charger in I have to spin it or wiggle it or both to get the battery to charge. Once I have it in position it generally stays on charge, but if the cable is...
It could be either one Sarah.
The AC adapter's (Charger) cable, or the DC Power Jack where the AC adapter plugs into the laptop.
This is an example of the DC Power Jack not installed,
http://www.laptopjacks.com/view_part/Acer-Aspire-ONE-AOA150-ZG5-DC-Power-Jack-AC351816.html
(You can click on the three views of the jack to enlarge)
1) Check the DC Power Jack to see if it's in good repair.
Battery removed use a small flat tipped screwdriver, and Gently see if you can move the Center Pin around in the jack.
See if the Center Pin will move side to side a small amount. There is supposed to be No perceptible movement.
Referring back to the closeup photos of the DC Power Jack, the flat blade-like prongs are upside down, in relation to how the jack sits on the motherboard.
The flat prongs go down through the motherboard, and are soldered to the motherboard.
If the center pin of the jack is stationary, but the jack as a unit moves around, one or more solder joints, (Connections) for the flat prongs may be cracked.
The repair consists of completely disassembling the laptop, removing the broken DC Power Jack, and installing a new one.
Acer Aspire One service manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
(Click on the blue - One - in Aspire One.
This is a PDF file. The computer you are using now has Adobe Reader on it which uses PDF files.
After you click on the file name (One) it may take up to 30 seconds before you see the first page.
It may also take additional time for the file to fully download.
(Took 12 seconds just now for full download)
No perceptible movement of the DC Power Jack? Suspect the cable of the AC adapter right near it's plug. (Plug that plugs into the DC Power Jack)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 25, 2011 | Computers & Internet
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
Will Not charge with brand new a/ power cord it will at times power on if moved the right way but quickly powers off if moved the port inside looks to be fine But I hear there is a pin type thing inside...
The problem is with the AC adapter itself and is a very common problem with Dell AC adapters. My suggestion would be to get an aftermarket AC adapter that can be purchased on eBay as the Dell adapter is around 100.00. You can pick up an aftermarket one on eBay for around 20.00. The problem is a resistor inside the AC adapter that senses when a Dell branded adapter is inserted. What happens is that the resistor will get damaged and since it doesn't recognize the charger as a Dell branded one anymore it won't charge. However it will still run the laptop as long as it's connected. A lot of aftermarket AC adapters bypass this function and work perfectly fine.
May 29, 2010 | Dell (04U621) for Latitude D600, Inspiron...
On AC Power
Your problem most likely lies wih the laptop power connector, the power cord connector is not making firm contact, that is why when you jiggle it connects. It might be the cord, you can check it by connecting it to another laptop exactly like yours and see if this plays up on that laptop, if it does then it is most likely the cord/power adapter. Don't connect it to a different brand name laptop, different brands use different voltages.
To replace the power connector on the laptop could be expensive unless you do it yourself, the laptop would need to be completely dismantled to get to the connector. Get a quote, they may charge for a quote, unless you accept the quote which may then be offset against the cost of the repair.
I recommend if the laptop is more than 3 to 4 years old, I would not repair it, put some blue tack around the connector to make the connection secure/firm, and put the repair costs towards a new laptop.
Dec 01, 2008 | Dell Latitude C400 Notebook
Dell Latitude D600 Notebook Logo
Alun Cox
