Question about RCA P60920BL 60" Rear Projection Television
Power I have a P60101EB we plugged it in in the garage and it worked fine. we took it inside plugged it in and got no power. i checked all my GFCI's in the house and none were tripped. could this be a fuse related problem? if so is there a power fuse?
  • 61 Answers
There is a fuse,if you have a ptk169 chassis,the fuse is behind the plug,if its a ptk 195,after removing the back cover,the fuse is close to the cord were it contacts the board, its a 5 amp fuse in both chassis's ,make sure the set is unpluged before removing the cover.
Posted on Mar 04, 2008
I have an Amana ptac hotel type thru the wall unit. The unit won't turn on - it's plugged in. The gfi button is popped out. There is power to the wall plug. Any ideas?
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
May 14, 2011 | Amana PTH123B25AJ Heat Pump Air...
Tip
Wiring a GFIC alternative.
When wiring a GFCI (Ground Fault Interrupter Circuit) receptacle you would normally connect the wire coming from the service panel or the hot wire to the LINE connection at the GFCI and then connect the other receptacles you wish to protect to the LOAD side on the GFCI. But let's say you have installed a GFCI in a garage circuit and want to run a wire to the garage door opener from that circuit without the garage door opener receptacle being protected by the GFCI but still want all other receptacles protected. Reason being that the garage door opener will trip the GFCI more often than not. You may also want to have a receptacle for a freezer in the garage. You do not want that freezer protected by the GFCI circuit as it may trip without your knowledge and cause all the food to spoil. Warning: Only install a single plug receptacle for the freezer and not a double plug receptacle. That way only one thing, the freezer, can be plugged into this receptacle as it is not GFCI protected. The way to avoid the breaker tripping is to connect the garage door opener & freezer receptacle to the LINE side of the GFCI. This way it is not protected by the GFCI and there is no danger of that receptacle loosing power due to a tripped breaker on the GFCI. When the GFCI trips power will still be available at any receptacle connected on the line side. On any GFCI you can connect two sets of wires to the LINE side. If you have more than two you will have to connect those together under a wire nut and then use a jumper wire to connect to the LINE on the GFCI. Look at the photo and you will see the 2 sets of holes to connect at the LINE side (Bottom) on the back of the GFCI receptacle. There are also 2 sets of holes to connect on the LOAD side (Upper). Of course you would use a wire nut and jumper to connect all the ground wires.8dd2149.png
on Dec 13, 2009 | Electrical Supplies
HI, I have a whirlpool refridgerator model # ed22gw, It worked fine then 3 days ago it triped the gfci I unplugged and tried different outlets with no other load on them and it would still trip the...
Refrigerators should not be run on gfci plugs .As they age , they will pull slightly more amps . Also , gfci plugs will weaken even though no previous problem with them . If you have a gfci plug behind the refrig , replace it with a normal type plug .
Mar 31, 2011 | Refrigerators
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Refridgerator freezer pops GFCI outlets
most gfci are 15 amp draws
its quite possible your refer needs 19 or more to start
i would reccommend getting the unit of gfci plug
Oct 12, 2009 | Refrigerators
Frig stopped running.
Maybe over pulling more amps the the GFCI curcuit can handle. Check all the GFCI plug and verify if there are anything else plugged in. Including hair dryers and / or flat irons.
Sep 02, 2009 | LG Heat cool Window Air Conditioner
When I plug my freezer to an outlet not gfi protected it works fine, but when I plug it into an outlet that is gfi protected it pops the breaker. I dont understand why.
All fridge and freezers should be plugged into an NON-GFCI protected outlet, since the inital start of the compressor can cause the GFCI to detect a millivolt surge, when the compressor starts, causing the GFCI to trip.
If this is in a kitchen, you should change out the outlet to a non-GFCI outlet BUT only to a single outlet that only has the freezer plugged into.
If it's in a basement, garage, or some other place with a GFCI outlet, you can change out that one outlet to a standard single outlet device of which ONLY the freezer will be plugged into and remain code compliant. You will need to make sure that any other outlets served by that current GFCI outlet stay protected, by installing the GFCI you swap out, and put it in place of the NEXT outlet in the circuit.
By doing that, you will have the first outlet that was the GFCI, now a single outlet NON-GFCI serving the freezer, but the next outlet in the branch circuit gets a GFCI outlet, thus protecting the rest of the circuit, in compliance with the NEC (National Electric Code)
If you need further help with this, please comment back and I'll check back later and provide you more detailed info. Of course, be sure to turn off the breaker to this circuit before making any changes to the outlets, etc.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | GE Freezers
Electric outlet does not work
LETS START HERE , MOST OF THE GFCI BREAKERS WILL SOMETIMES RUN THROUGH THE BATH ROOM OUTLETS AND THEN OUTSIDE IF YOU HAVE A GFCI IN THE BATH OR LAUNDRY OR BASEMENT OR GARAGE MAKE SURE NONE OF THE RESET BUTTONS ARE IN THE TRIP POSITION THE NEC CODE CALLS FOR ALL OF THE LISTED PLACES AS WELL AS CRAWL SPACES AND NEXT TO AC/HEATPUMP TO BE ALL GFCI AND TO SAVE MONEY AND WIRE MOST OF THESE ARE DAISEY CHAINED TOGETHER TO SAVE MONEY SO THEY PUT ONE CLOSE TO THE BREAKER PANEL AND FEED THE REST OFF IT IT WILL BE A GOOD CK I HAVE HAD MANY CALLS FOR THIS THROUGH THE YEARS
Dec 09, 2008 | Rival S12T Electric Skillet
Televison & Video Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
