Question about Acer Aspire 5100 Notebook
I'm trying to restore the computer to factory standards
I have already backed up the computer to disk now I'm trying to do a complete restore on it but nothing is working does anybody know what I need to do? It is an Acer aspire 3680
  • 53 Answers
Open the Acer eRecovery Management Software, and make sure you burn all the disks you need to restore the system.
Then, using those discs, you should be able to reinstall the system.
Posted on Dec 11, 2008
Im trying resore my acer back to factory settings
Did you press 5 times
If you do NOT have a copy of this disc, skip to step 3 for further instructions. Once you restart your computer, a screen will appear with the words. Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings. Follow the on-screen prompts to finish the installation. Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again. Restart your computer to complete the restore. 3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk. Unplug all external devices and restart your computer. When the loading screen comes on with the Windows logo, press Alt+F10 together five times. This will bring up the system restore menu. Follow the on-screen prompts to restore your computer back to the factory settings Hope this helps.
Jan 20, 2013 | Computers & Internet
Mi notebook acer aspire 3000LCi the only do is a an upper and i dont have a recovery disk
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
hope this helps
Oct 17, 2012 | Acer Aspire 5610-4648 Notebook
HOW CAN I RESET THE HP OMNI 100 BACK TO ITS FACTORY SETTINGS
You will have to get a factory restore disk and if you already have one place in the DVD or CD tray and start the computer follow the on screen instructions to restore the computer back to its original condition. Some PC's have a separate restore partition on the C:\ drive you can go to my computer and tick to open go to C:\ and see if there is a partition for this. It should say recovery or restore. If you do not have this option you may order one from the factory or go to their web site and download a copy of the original software. NOTE: people when you buy a computer and have this option to download restore disk by all means do so right away. Also store you factory disks where you will find them if ever needed.
John
Apr 16, 2012 | HP Omni 100 PC
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
How do i restore my hp hdx18 to factory install settings? completely wipe it
Turn the computer off.
Turn the computer on, and look for a message like "press BLAH to enter System Recovery".
When you see the message, press the BLAH key.
This will start a complete "restore-to-factory" install of Windows.
Or, if you have a set of "System Recovery" CD/DVD disks from HP, then insert the 1st disk,
restart your computer, and select to boot your computer from the CD/DVD drive.
Or, there may be software already on your computer that lets you "burn" a set of "System Recovery" CD/DVD disks -- have 10 CD-R disks, and 5 DVD-R disks -- you may need to use most of these "blank" disks.
Apr 23, 2010 | HP Pavilion HDX18T Laptop
I want to restore my qtec pc to factory condition
ok if you have the disk, install the disk and follow instructions.
if no disk some computers will do a system restore by selecting either
F9 or F12 if your computer is not compatible with these options
try going to start all programs then acsessories then system tools.
in system tools go to system restore. select a date that you wish to restore to. and allow the restore to complete.
remember to back up your files .
Nov 15, 2009 | Dell XPS 200 PC Desktop
How do i completely reset my laptop to factory settings without a disk.....my pc is completely infected by viruses
try these steps, hope they will help you:
1. Copy all your files and documents to an external storage device.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish"
let me know if it helps you.
Oct 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
How to reset laptop vista to factory settings
Try my steps and let me know about it:----------- Hope they will help you:
9. "Next"
10. Click "Yes"
Sep 19, 2009 | Toshiba Satellite Pro L300-EZ1005X...
Can't restore to factory spects
Beat me to it pontelemon.....lol.
Just as the Guru said and mine is...see below.
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process.
Apr 09, 2009 | Computers & Internet
Formatted the player
Here is what I was able to find on the apple web site. I hope it works for you. Restoring iPod to factory settings Learn how to restore iPod, iPod mini, and iPod nano to factory settings. If you need to restore an iPod shuffle, click here. Background It is important to understand the difference between "update" and "restore". Update simply installs the software that controls iPod and does not affect the songs and files stored on iPod's disk. Restore erases the iPod's disk and restores iPod to its original factory condition. Warning: because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library. If you use the Nike + iPod Sport Kit, see this document for more information. -------------------------------------------------------------------------------- How to restore iPod Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install iTunes 7.0 or later if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator?s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time. Here is the link to where I got this info: http://docs.info.apple.com/article.html?artnum=60983
Sep 02, 2007 | Apple iPod nano
Acer Aspire 5100 Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
