My washing machine is not letting any water out and i can not get the filter out
  • 135 Answers
What make plz
Posted on Dec 11, 2008
Door will not open after washing cycle ends on SamsungWF8704RSW washing machine
If water still in machine saftey feature will not let door open. Machine may have been over filled with washing, or filters may need cleaning, or both. Set the machine to do another spin cycle, sometimes needs to beredone several times. Clean your filter in normal way but be careful as water in drum could drain through filter.
Sep 15, 2016 | Washing Machines
After the cycle is complete our Whirlpool Duet Front loader washer leaves liquid detergent in the wash tub and the dispenser. Please let me know your thoughts? Thank you.
it might be that one of your water valves have gone or the filters are blocked on the water inlets( try this first turn your water valves off at the the tap end take the cold pipe off at the back of your machine and there are little gorse filters in the pipe or water valve take them out and clean put back do the same to the hot and try the machine on a wash let me know if this has helped
Nov 12, 2011 | Washing Machines
Hot water won't go into the washing machine, only the cold water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 07, 2011 | Maytag Washing Machines
Put my washing on at a 60 degree wash for 1 hour 40 mins. Went back to machine several hours later, there was tiny amount of water on floor and machine had water in it but the wash had not progressed any...
Sounds like a blockage perhaps the filter needs cleaning or pump blades jammed...If its a Hotpoint then filter is middle of sump hose connected to the drum....
Jan 06, 2011 | Washing Machines
Crystal-like substance
It sounds like your water system might need some filter housings installed?-- are there any filter housings in any of your water systems?-- If so, what are they accumulating-- what do you find, when you change filters.
Write back what you are finding.. If you have no filters, then let's install either ONE on your common cold water supply to the house-- or start with two at your washing machine. Which would be easier?- Write back-- Mack Baxter
Nov 02, 2017 | GE WBSR3140DW Top Load Washer
Will not pump water out
My grandmother had the same problem. Lets see if it's the same one. Maybe, your water filter is clogged. Washing machines have a water filter right before the water comes out. Try cheking that out, maybe it's clogged by hair or something like that.
May 09, 2009 | Washing Machines
Washing machine it shuts down water filling cycle
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Jan 29, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Descaling
Remove the filter holder (portafilter).
The manual says to unscrew the nozzle from the filter holder coupling and wash with hot water.
Mix a liquid decalcifier with water in tank at a 1:1 ratio. DO NOT USE VINEGAR! It says to fill the water reservoir.
Run the cleaniing solution through the machine - pressing the coffee button, 1 cup at a time. During each interval let the decalcifier act for 10 or 15 minutes by turning off the machine by the main switch.
Carefully wash the tank and fill with fresh water and empty 2/3 of this by pressing the coffee button.
Now let the machine warm up and empty the rest of the reservoir by rotating the hot water/steam knob.
Screw the nozzle in the filter holder coupling again.
Jan 06, 2008 | Saeco Magic De Luxe Espresso Machine
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
