The gear oil is the final drive oil - on the back wheel it's the hub assembly that the drive shaft ties into. There's a bolt at the top of it for filling and one at the bottom to drain. You should drive the bike a little to warm the oil, then you can drain the oil through that lower plug. I usually open the filler one on top while draining and I pour some fresh gear oil in to kind of flush it. Then install and tighten the drain plug. Fill with fresh oil right to the top of the filler plug. Some drain plugs are magnetic to pickup metal debris (normal) so clean that off when you have it out.
SOURCE: What weight gear oil should be used for the 650
80/90 wt Hypoid gear oil is used in Transfer cases and final drives
SOURCE: 1999 vstar 650, no power, stalling out at idle.
have you checked the carb for dirt ?
sounds like the carb is dirty and or the idle screw has moved
Testimonial: "I pulled the carbs off, removwed float bowl cover, found one of the jets was clogged. All good now!!!!!"
SOURCE: 2002 yamaha 650 vstar, 20,000 miles. it won't
Could be the coil. Also could be several other things. Download a shop manual and diagnose it.
SOURCE: I have a 2002 VStar classic 650 problem with high speed vibration
I would guess that the tires need balancing. There is a product you can buy that is a bunch of little BB's you put in the tire that will balance it. I have not used it so I would recommend taking your bike to a tire shop and have them balace it for you.
