My laptop has an adapter problem & it is not able to access WLAN.what shall i do ?
  • 449 Answers
Adapter problem has nothing to do with wirelesslan, get a new adapter so that will can solve it step
Posted on Dec 11, 2008
I seem to not be able to find any wifi drivers for my Everex StepNote NM3500W laptop im on xp an need to access my internet on my other pc.
Try this drivers for your wifi adapter.
ATHEROS AR5005G Wireless Network Adapter for XP -> Download
Hope it helps.
Nov 11, 2010 | Computers & Internet
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
Can not access sitecom 300n with factory preset 192.168.0.234 or find trouble shoot in manual
open Network Connectdisable the wlan adapter first. open Network Connections from Control Panel and disable the wlan adapter first.Then Open Properties of the (wired) LocalArea Connection. Scroll down to TCP/IP and Change the Properties: IP=192.168.0.2 and Subnet Mask=255.255.255.0. Then connect the Sitecom using the wire (UTP). You should be able to browse with an internet browser to 192.168.0.234 now. After setting up the Sitecom disconnect the wire and enable the wlan adapter again.
May 15, 2010 | Computers & Internet
Cant get my wireless connection to work not sure
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
Apr 01, 2010 | MSI Wind U100-030US Laptop
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
Wireless light is off.
I am now on the same kind of computer and I used to have this problem- dell said it's a motherboard problem and they replaced it for free. Now it works just fine!
Jun 14, 2009 | Dell Vostro 1510 Laptop
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting to woreless internet connection
Be sure you use same security protocol on your PC than in your WLAN:
WEP or WPA or WPA2 protocol
Passphrase (PSK ) or Password
TKIP or AES.
Use same Key.Passphrase on your notebook as in your Access point.
Check if your Access point/router has access list enabled: either you disable it in your AP either you add your PC MAC address to the list.
Dec 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Notebook won't connect to network
1) Verify if Wi-Fi WLAN interface of your notebook is OK.
1a) Check whether HW switch is ON and the wireless system service is running.
1b) Switch on the WLAN Access Point (router) SSID broadcasting.
1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
4) Select your home WLAN SSID in the list and try to connect.
5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
6) In success case set the WLAN security.
Dec 20, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
