Question about Dishwashers
My Whirlpool dishwasher washes but does not rinse or dry
I have tried hitting the "heated dry, normal,heated dry, normal" sequence as well as the :hi-temp wash,heated dry, hi temp wash, heated dry" sequence with the dishwasher door open. All the lights come on , I close the door, and about 10 seconds later ,all the lights turn off. I have then hit" cancel" and then "normal",and then "heated dry", then start...... the wash cycle will run for hours but will not rinse. I have been able to repeat the reset sequence and run the "rinse cycle by itself and it seems to run properly
  • 1 more comment
  • dan doughtie Jul 15, 2012
    additional info relating to the dishwasher : it does drain properly when the "cancel/drain" button is pushed
    whirlpool quiet partner ii (model # DU1145XTPBO)
  • dan doughtie Jul 17, 2012
    after reviewing everything i could find on Google , I am inclined to believe the problem is in the control board. i will let you know how it goes
    Top Expert:
  • Dishwashers Master
  • 85,020 Answers
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Posted on Apr 25, 2017
SOURCE:
How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
Oct 20, 2011 | Whirlpool 24 in. GU1500XTLS Stainless...
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
My machine is portable. Model: DP840SWPXO, Serial: FS1107915 It was washing a load of dishes. Set at "HEAVY/NORMAL & NO HEAT/DRY". It stopped working between the NORMAL and RINSE ONLY part of...
Hello & Welcome to FixYa
This can be reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
You can clean the drain pump assembly if the problem returns. Please get back to me if you have any other questions.
Kevin
Feb 06, 2011 | Whirlpool Dishwashers
The "rinse only" button will
Hi
If rinse light is flashing then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Jan 06, 2011 | Dishwashers
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
I have a Whirlpool Dishwasher Model #GU240CXTPB1. The normal light won't stop blinking. Tried turning the breaker to reset, but still blinks. No other button works.
Whirlpool dishwasher reset sequence is usually to hit the heat dry then normal then heat dry then normal buttons within 5 seconds and it usually resets.
Mar 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
