Question about Dishwashers
How to put gasket on then motor on dishwasher
  • flyingtarzan May 11, 2010
    what brand and model please?
    Scholar:
  • 82 Answers
Hello. I am not sure which brand of dishwasher you have, but the ones I am familiar with, you have to put it directly onto the motor and then you need to put some liquid soap on the gasket so that it doesn't bind when putting it back on thus causing a leak.
Posted on Dec 12, 2008
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool Dishwasher GU1500XTL Leaking from wash motor
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
q3taga
Aug 31, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a leak from my dishwasher. I have checked the waste pipe and water inlet but all feel quite dry. The water is grey which indicates i must be dirty water. Can you help?
Without knowing the manufacturer and model number of your dishwasher, I can't be very specific. But given the connections (both intake and drain) are not the source of the leak, the problem could be in the gasket between the motor and the cabinet (or higher where the impeller is attached.) If the gasket above the motor is the source of the leak, it is very possible that the motor is damaged and will fail. If you replace the motor, confirm that it ships with the gasket.
The other possibilities is a rusted hole in the bottom of the cabinet. A flashlight in the dishwasher while watching from the bottom may be a good way to inspect.
Please report back with what you find and we can take the next step. OK?
Aug 10, 2009 | Dishwashers
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Danby DDW396: pump leaks when in use.
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 11, 2009 | Danby 22 in. DDW396 Free-standing...
Dishwasher leaks when jet dry rinse is added everytime.
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Nov 27, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Caloric Dishwasher DUS203190A
Hi thanks for the question On a ge dishwasher , more often than none it leaks from the motor seals If thats what the problem is you will see it leaking from the motor shaft , It could be leaking from above the motor if it si from the tub ,Replace the part that joins the motor to the tub if its motor seals .Replace motor seals
Sep 07, 2008 | GE WHRE5260E Top Load Washer
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
