Question about Panasonic ET-LA702 Projector Lamp for PT-L501X, PT-L511X, PT-L701
Panasonic PT-L701e - colour fault, blacks are blue with lines
Through both video inputs (svideo and composite) the colour is bad, blacks/dark images are blue and there are horizontal lines through this blue, if the contrast and brightness are turned up the blue fades but it makes the picture too bright to watch, the scoruce is a sky box with good signal from scart to svid or scart to composite, the lamp is showing only 1702 hrs use (it did have a new bulb recently but dont recall if the lamp timer in the menu sytem reset itself at this point?) the projector has been sited in the same position in a smoke/dust free environment since purchased.
I am stumped, please let me know if you can help..
Thanks
Terry Hunt
  • 57 Answers
Can you connect a computer (vga) signal to this projector? I'd like to know what your "white" computer screen does on the projector....example, Excel spreadsheet....
I am leaning towards these problems, a bad video card...or worse delamination of one of your LCD panels and possible polarizer burn in the optical engine.
Best Regards,
Steve
Posted on Dec 12, 2008
I have a samsung lcd tv that powers on has sound but the picture is fuzzy and has no colour . What would be the component that needs replacing for this ??
Hello. Before you start replacing parts, make sure your connections are correct. It sounds like you have connected a composite source to a component input. Composite is three RCA plugs, a yellow for all of the video, and a red and white for audio left and right channels. Component is five RCA cables, green, red and blue for video, and red and white for audio. if composite is connected to a component input, the picture will be black and white with squiggly lines all through it.
Mar 31, 2015 | Samsung LN40A550 LCD TV
CRT RPTV B&W image composite input
How many times this standby/power light blinks at one time Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 19, 2013 | LG Televison & Video
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Component Input 1 & 2 gives black & white picture
You will need to connect all the cables for component to get a colour image.
The component cable has 3 connectors all for video. If you have connected only one cable for video then you will not get colour information. Component needs all 3 to get colour and luminence information. You can use a regular composite cable but you have make sure you match up the colour codes on both sides i.e to TV and to the source. The other two Red and White a separate cable is for Audio.
Y-> Green
Cb-> Blue
Cr-> Red
Jan 17, 2011 | LG 46LD550 46 in. LCD TV
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
Dear Sir My Dvl 919 dvd player component output give black and white images no colour but SVHS have color images.Pls advise Erwin Koh
there are three wires associated with "component output" .. those have to be hooked up to component inputs on your TV .. not to the composite video input .. if you do hook up to composite you will get only a black and white picture .. make sure all three wires are connected correctly then select the proper input in your TV setup ..
Jan 27, 2010 | Televison & Video
Hooked up a wii to front av inputs. I have no wii
Make sure the Wii's analog composite video output is enabled. Try resetting the Wii to factory defaults. this will default to enable the composite video output.
You can find the procedure in the Wii manual.
Dec 26, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I INSTALLED MY ATI RAEDEON 128PCI VIDEO CARD AND IT HAS S VIDEO OUT AND COMES WITH THE SVIDEO TO RCA CABLE BUT I CANT GET THE IMAGE TO DISPLAY ON TV
The S-video to Composit adaptor tells me that you wish to connect to the Composit input of the TV
Connect the TV , set the TV to ( Composit input ) Composit 1 , or Composit 2 , NOT A CHANNEL
restart the computer , this will help the video card and software to detect that the TV is now on and connected.
When you come back to windows you should be prompted to perform the television setup wizard
if not
go to your display properties
Advanced tab
and manualy configure the video card for television output.
Selah.
Sep 15, 2008 | Computers & Internet
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic ET-LA702 Projector Lamp for PT-L501X, PT-L511X, PT-L701 Logo
347 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
