Question about American Range AF-25 Deep Fryer
Connecting wires for AF 25
Hi this is varinder . i have a AF 25 American range fryer. I just changed the thermostat switch of that one.and i plugged out both the thermostats and wires also . Now I'm having a problem to fix the wires of that one. can you please help me to fix the wires and make it work properly. I'll wait for your mail .
thank you
  • American Range Master
  • 8,220 Answers
  • Dan Webster
    Dan Webster Dec 15, 2008
    I refuse to try and wade into the internet to beg for schematics of your fryer. All of them work the same basically. Post me a picture of your fryer's gas valve so that I will know if it is a millivolt type, gas operated, or electrical.
WISH TO KNOW BTU"S FOR MODEL AF-45 ????
Good Luck! there is not enough information to answer this question however FYI: A Brand New American Range Deep Fat Fryer Model AF-40 can be obtained with 90,000 BTU's Nat or LP gas
Apr 07, 2014 | American Range Kitchen Appliances - Others
My fryer wont lit up the fire.only the pilot works
Check if there is sufficient gas supply as stated on the unit's nameplate. Check if there is no soot/ carbon build up on the thermopile for this will lessen the heat from pilot thus reducing milli volt it will generate to open the main valve, in short, main burner will not fire up if there is soot/ carbon on thermopile. Check and tighten also all of wiring connections.Check if the thermostat is set at higher temperature. If all of these did not correct the problem, try replacing the thermopile.
May 14, 2011 | American Range AF-25 Deep Fryer
How can I convert from natural gas to LP?
change your gas get from natural to lp and use an lp regulator. you may have to adjust your air flow for proper flame
Sep 16, 2010 | American Range AF-25 Deep Fryer
Gas Valve Knob - Fits Robertshaw 700
try Elliott Refrigeration in Belleville, On and speak to Diane.
Oct 13, 2009 | American Range AF-25 Deep Fryer
Flames in the exhaust of my american range deef fryer
Is this a propane unit?If so the baffles get clogged with soot and burn.Let me know.
Feb 27, 2009 | American Range AF-25 Deep Fryer
Deep-fryer thermostat
It is possible that the heater is shortened and it burns thermostat. Thermostat's are usually bimetal type mounted on ceramic so voltage does not matter a much.
Jan 13, 2009 | Kitchen Appliances - Others
Problem in connecting wires
Hello, here is a web address to American Range, this should take you to there documents for wiring diagrams. Pick your model/unit type, and this should get you going.
http://www.americanrange.com/info_package.html
Hope this helped, and thank you.
Dec 14, 2008 | American Range AF-25 Deep Fryer
Fryer wires
hi verinder, this is tom go to your search bar type in american range fryer pdf fill out the form and they will send you a wire diagram tell them mo#
American Range AF-25 Deep Fryer Logo
119 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Mike
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
