Question about Sharp AL-1217 Copier
L1 is flashing on my copier
My Sharp AL-1217 is flashing L and 1 intermittently. It is neither printing nor copying. The power on light is also in off position. How can I photocopy and print?
  • ij_nkiru Dec 11, 2008
    any solutions yet? Please respond quickly. I am standing bye.
    Novelist:
  • 103 Answers
Hello, Please check out the following website and see if you can find your error code:  http://www.copier-help.com/copier-help/
Hope this helps. Good luck
Posted on Dec 11, 2008
  • Harold Bean
    Harold Bean Dec 11, 2008
    I have an update to your problem:
    A letter "L" and a number "1" appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Old model AL-1217 photocopier giving error reading of L? Any thoughts, tried everything! Thanks
L1 mean scanner is not goes home position,
Solve: Clean all surface then solve your problem
Feb 06, 2010 | Sharp AL-1217 Copier
I have a sharp al1217d the L1 light flashes i have no lock on cleaned all surfaces but still flashes any ideas?
Press stop key and press auto exposer key same time 2 trems power of the machine press 14 and press start key
if not solve
contact nasmamtrade@yahoo.com
088-01710 950340
Jan 24, 2010 | Sharp AL-1217 Copier
Often Flashes F5 shortly after power up and then cannot print or copy
It is copy lamp lighting abnormality. It could be a mulfunction with copy lamp, ccd or the wire harness.
May 11, 2009 | Sharp AL-1217 Copier
My Sharp AL-1217 keeps flashing H4 and does not respond
This is a typical fuser lamp issue. This is usually caused by a fluctuation in current supplied to the fuser assembly when the copier is warming up.
This cannot be solved by powering off the unit nor by unplugging it!
Follow the simple steps below to correct the issue:
  1. Power on the unit.
  2. When the LED display starts flashing "H" and "4", Press C and Auto button(this is the leftmost button with the copier console facing you)
  3. Repress the C and Auto Buttons again
  4. Press the copies button until 14 appears on the LED.
  5. Then Press the BIG Blue COPY button(the rightmost button with the copier console facing you)
Hurray, that's all folks
Mar 25, 2009 | Sharp AL-1217 Copier
Flashing "L1" error
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
My sharp AL-1217 greets me with a flashing "L1" error
try to clean the scanner glass, it has a white stripe at the home position of the scanner optics, clean it well.
Jul 28, 2008 | Sharp AL-1217 Copier
AL 1217 noise when started
hi first u check with out drum and toner unit. that time also u getting noise u check main drive assembly and fuser assembly.
Jun 24, 2008 | Sharp AL-1217 Copier
Scanner Position Error
hi i think this is carrage home position sensor problem. u check and clean the sensor and try it back. or any forign meterial blocking in carrage way.. pls check that also.. all the best..
Jun 23, 2008 | Sharp AL-1217 Copier
235 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
