Question about Motorola Mobility TracFone C139-4 Cellular Phone
Cell phone reading invalid battery when i try to charge it
My motorola tracfone c139 says invalid battery when i try to charge it. Does that mean a problem with battery or charger?
  • Anonymous Dec 21, 2008
    help.........
  • billp21 Jan 13, 2009
    I have a C139 Tracfone and the battery recently died.
    When I tried to charge it I got an "Invalid Battery" message.
    I tried another battery of the same type but I still keep getting an "Invalid Battery" message.
    Any help would be greatly appreciated!
5 Suggested Answers
  • 61 Answers
SOURCE: How do I get my voicemail from another phone?
You should be able to call your cell from a landline, then press either # or * then enter your PIN. Most cell services are that way.
Never it tried with tracfone, but it should work.
Posted on Mar 07, 2008
nandosnut
  • 112 Answers
SOURCE: American Tracfone Motorola C139 in Europe
I suspect that we are talking at cross purposes. Each SIm has the facility to lock/unlock; that is a security feature. Airtime providers also lock their phones, though, and that - I fear - is what you have here.
Which country are you in and which Airtime provider's SIM have you purchased? Has the SIM been activated?
I have dealt with most UK Airtime providers, Vodafone in Italy, Greece and Cyprus, plus Movistar in Spain.
Posted on May 20, 2008
  • 5 Answers
SOURCE: beeps while talking
Sure. Use the Menu key to naivigate to the Settings Menu.
Go to the In-Call Setup and select it.
Under In-Call Timer go to Beep and turn it off!
Voila!
Posted on Jun 03, 2008
SOURCE: setting up my voicemail on my Motorola C139 TracFone
Elementary, just as you would in any other phone, just dial your number, and the phone will talk you through on setting up your voicemail.
Posted on Jun 18, 2008
  • 17 Answers
SOURCE: how to unlock the motorola c139
Press the "Menu" button and then the asterisk "*" in quick succession.
Pressing these same two buttons again will lock the phone.
(Note: the "Menu" button is the button in the center of the up, down, left, and right arrows. The asterisk "*" button is on the bottom left of the keypad.)
Posted on Jan 13, 2009
Tracfone beeping while charging
Probably a pending message or low battery.
Mark
Motorola Support
Apr 15, 2014 | Motorola Mobility TracFone C139-4 Cellular...
Invalid sim on screen
If your phone show Invalid SIM it means the SIM card is corrupted you will have to change the SIM card.There is no other option.
May 19, 2010 | Motorola Mobility TracFone C139-4 Cellular...
Tracfone-motorola double minutes does not work at all
If you have pets, they might be responsible. If not, be careful, because you might have a leaking battery.
Feb 24, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Batteries for motorola Tracfone
is there battery plus place around your area
Feb 04, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Phone dead
Here's something quick to try:
Have the battery tested to see if it holds a charge (This can easily be done by using an inexpensive multimeter). Place the multimeter leads on the battery terminals (red on plus, black on minus sign). Set the multimeter to DC voltage, 0-12 VDC. Let the phone charge for 4-6 hours with the battery in. Unplug the phone & take out the battery. Test the battery as explained above - if it isn't holding a charge...then the battery's probably bad (purchase another battery).
It sounds like your're stating that the phone works only when you plug it in, so I'm assuming that the power adapter and the plug recepticle are in working order - otherwise, the phone wouldn't work.
Mar 18, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Motorola c139 annoyance
Yes there is a solution, keep your phone on silent when it is charging. It works for me.
Mar 14, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Motorola Mobility TracFone C139-4 Cellular Phone Logo
330 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
